![]() | Home > Wheels & Tyres (L663) > 22" r524 wheels on Defender 110 X ? |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Do be careful buying “cheapy” wheels, especially big ones as there is a lot of history over on the Range Rover and Sport sister forums of them failing at the first pothole taken at normal city road speeds - these cars are very heavy and often cheap aftermarket ones aren’t strong enough for even on good paved roads and crack easily. Anything with the LR Oval cast into them should be fine but they will cost a bit more for the strength. The style you show was an OEM on Range Rover Sport and Range Rover Evoque but I don’t think LR ever sold it in a size bigger than 20”, what you have seen in 22” could be a copy of the LR design. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
rutiger Member Since: 30 Dec 2020 Location: wa Posts: 32 ![]() ![]() |
i think the cheap comment referred to choosing an OEM smaller/base wheel instead of the OEM 22" option
pjm-84 Member Since: 12 Apr 2021 Location: Hampshire Posts: 701 ![]() ![]() |
Similar to a style that Urban use. May be worth having a look on their website.
https://www.urban-automotive.co.uk/urban-range/defender-2020 |
rgeezzy Member Since: 09 Jul 2021 Location: 44147 Posts: 10 ![]() ![]() |
I appreciate the fdback guys.
Any addtl insight on the spacer sizes would be greatly appreciated ... |
2022 Carpathian X finally came in and I was able to get the rim/tire combo I had envisioned in my July post.
285/45/22 Contis via TireRack and 22" x 9.5" OEM-Style Range Rover SVRs in Gloss Black via EuroWheels. Just destroys that miserable OEM 22" x 9" factory option, doesn't even compare. Prob gonna put 20mm spacers on rears and 10mm on fronts. Vulkan Spoiler shown. https://vulkanautomotive.com/collections/1...ar-spoiler Vulkan Wheel cover shown https://vulkanautomotive.com/collections/1...3321245889 Simply Splendid ! ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Leeds Utd Member Since: 07 Jan 2022 Location: RP Posts: 119 ![]() ![]() |
Looks Great !!!
craggleboy Member Since: 01 Apr 2024 Location: Wivenhoe Posts: 1 ![]() ![]() |
Looks awesome! Did they just fit, or did you need the spacers you referred to or you just want for cosmetic appearance? I like Range Rover Sport Vogue 22" Alloy Wheels Style 5131's but can't work out if they will fit, or whether I will need spacers..
Dimensions - 9J x 22 ET42.5 Part no - LR167476 Manufacturer part no - N9XM-1007-AA Stud pattern - 5x120 |
