Home > My Defender > hanks Double Cab
Page 13 of 21 <123 ... 121314 ... 192021>
hank
Don't think I can justify ATB's at the moment. Looking for a cost effective way to upgrade just the front diff rather than changing both front and rear to expensive ATB units Laughing Four pin diff up front will be ok for my drive to Italy
Thinking Aschroft's 4 pin diff centre looks like a reasonably priced option. I also have a spare diff I could use for buildup https://www.ashcroft-transmissions.co.uk/4-pin-diff-centre.html > 110 XS Double Cab
Post #910268 1st Jul 2021 10:55am
bankz5152
When I spoke to Nige at Xcess4x4 pegged 4pin diffs where the same as pegged ATB within about £50 or so Instagram @defender_ventures
Empire Tuning - Agent
Post #910270 1st Jul 2021 11:14am
hank
Air con gassed today with the new condenser. No leaks detected on the leak test, 700g gas, leak tracing fluid and oil pumped in... Icy cold air conditioning once again Thumbs Up Will make a big difference driving through France.
One thing the guy said which I had completely wrong in my mind was to use the AC as much as possible. I actively try to use it as little as possible, kind of preservatively I suppose. He said this does the components no good. > 110 XS Double Cab
Post #911581 9th Jul 2021 8:51am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
As well as the refrigerant gas there's some oil in the system. Among other things that keeps the O-rings from drying out. Additionally, AC is good for dehumidifying the interior, which given most Defender's sieve-like tendencies is no bad thing.
So, if you use the AC it will eventually wear out. But if you don't use it the AC will die without any benefit. Personally I use mine at least once a week regardless of the temperature.
Post #911599 9th Jul 2021 10:18am
Dinnu
10-15mins on a regular basis is enough to keep it from 'drying'. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #911601 9th Jul 2021 10:38am
hank
Bigger 14" SPAL AC fan fitted to condenser
 > 110 XS Double Cab
Post #914078 26th Jul 2021 11:09am
Welshsurferdude
Wales
Ill be fitting the same once I find my new 110! 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #914088 26th Jul 2021 12:05pm
L110CDL
That looks much better to do the job properly Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #914325 27th Jul 2021 8:26pm
hank
Missed your reply Clayton - thanks!
Made a start on the dogs seat for the drive down to Italy. Having the dog in the front frees up the rear seats for luggage which is essential since double cabs are crap for load space.
These front centre seats are not meant for Puma's and their mounts position the seat too far forward meaning it nudges the transfer box shifter into neutral so I cut the mounts off and welded in two lengths of 25mm square hollow section to the seat frame which pick up to the cubby box fixings.
I appreciate that this would fail an MOT and that the cubby fixings are not beef enough to mount a seat etc... But it's just somewhere for the dog to sit and will be swapped back to the cubby when I return home
Had to wait for the paint to dry but will fit the seat covers and put it in the Defender later
 > 110 XS Double Cab
Post #916346 10th Aug 2021 2:15pm
Zed
What a great idea, looking forward to seeing it fitted. How big is the dog? WARNING.
Post #916373 10th Aug 2021 4:06pm
hank
XS seat cover fitted and in the vehicle. Bit of a squeeze with the premium seats!! Dog is small/medium, around 16kg… Jack Russel mongrel cross
 > 110 XS Double Cab
Post #916377 10th Aug 2021 4:36pm
Co1
Very tidy install. Looks great.
Post #916384 10th Aug 2021 5:26pm
bankz5152
Looks good! You say that about the middle seat, but the standard front seats are held in place with 4 oversized m8 rivnuts. No different to the cubby box fixings.. Instagram @defender_ventures
Post #916401 10th Aug 2021 6:54pm
hank
Next job this evening was the panhard rod bushes. My steering had developed a notch between left and right turns as well as a general feeling of vagueness. You could see the rod eyes move with steering input!
Ordered a superpro full vehicle kit from Gwyn Lewis and did the panhard bush this evening… Notch is gone and steering is a lot more positive. Will get the other bushes on over the next week or two.
 > 110 XS Double Cab
Post #916403 10th Aug 2021 6:58pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Seat is looking good!
Will be interested to know how you get on with the super pro bushes. I’m torn on whether to go for super pro or genuine in the future.
Post #916405 10th Aug 2021 7:21pm
