![]() | Home > Off Topic > Garage door threshold seal |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 ![]() ![]() |
Has anyone any experience on which garage door threshold seals are good/bad.
I have fitted electric roller shutter doors to my garages and whilst the doors are flush to the floor I wish to keep ALL water/dust out if I can. I am looking for something that is about 25mm high at the most. Any suggestions good OR bad Cheers Guy May your life be like toilet paper ; long & useful. |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
Interested in this myself if anyone has experience of fitting one
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2664 ![]() ![]() ![]() |
Is this any good for what you need
https://www.expandingfoamtape.co.uk/produc...0c2fa87a8e |
pjm-84 Member Since: 12 Apr 2021 Location: Hampshire Posts: 701 ![]() ![]() |
Might have to think outside of the box depending on your situation. Alway worth a look but I cant remember length limiations.
https://www.assaabloydooraccessories.us/en...hresholds/ On new commercial builds the only solution that works is to create a "waterbar arrangement" behind the door via an stepped armour joint profile. |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945 ![]() ![]() ![]() |
Or this....?
https://www.ebay.co.uk/itm/283681359083 |
Not looking for a foam type of strip but most likely a rubber type of strip that goes inside the garage and butts upto the door.
As PJM suggested Guy May your life be like toilet paper ; long & useful. |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357 ![]() ![]() ![]() |
I fitted one of these on a single garage door, so far done a great job keeping the leaves out.
https://www.screwfix.com/p/diall-garage-th...2-5m/616fr Keith |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1438 ![]() ![]() ![]() |
Used this numerous times and works a treat ![]() Let it lie flat for a day or so and easier to apply on a warm day. You can also get various lengths, simple and effective. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
I'd be minded to go for a hollow P or D profile EDPM seal which will seal nicely under compression
Something like https://www.ironmongerydirect.co.uk/produc...own-699105 https://www.amazon.co.uk/Fafada-Interior-E...amp;sr=8-5 https://www.amazon.co.uk/MinticeTM-8Meter-...9&th=1 > 110 XS Double Cab |
