![]() | Home > Td5 > Td5 90 side sills - missing? |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
Photos might help
![]() 2008 SVX 90 2000 XS TD5 90 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5811 ![]() ![]() |
Yes you remove the side sill when you fit sliders to a Defender. About 50mm in depth, and are just pressed aluminium and held on with small m6 bolts.
Vera's Driver Member Since: 26 Mar 2021 Location: Oxfordshire Posts: 19 ![]() ![]() |
Thanks. Yep, from your link , bought the black bits (protectors) but do not have the silvery bits in situ to fit them too. Guessing these are brought separately which is what I need but lack the know how as to what to look up . Pictures on “part “ sites are not clear or particularly informative.
These are some of the part numbers.
RTC6206 & MTC8293 |
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 ![]() ![]() |
Check out YRM 1 piece side sills, thicker & better quality and look factory once painted
