Home > Maintenance & Modifications > Alternative EMS
rsms
Slovenia
Alternative EMS
I just want to share my experience with engine monitoring system I have installed recently.
I wanted to monitor "vital signs" of my Defender TD5 (coolant temp and level, EGT temp, oil pressure). I have read a lot of positive reviews and very good experience people have with Madman´s EMS 2 and recently with EMS 3 all over the net. Despite the relatively high price this unit would cover all I want (and probably more).
Then I stumbled at this:
Not quite what I wanted (no EGT and oil pressure, engine temp instead of coolant temp).
But there is alternative:
Now the coolant level is missing and there is still no oil pressure monitor...
The seller said they can re-program the gauge, but there are max 3 inputs to monitor and sorry - there is no oil pressure sensor (yet?). I decided I`ll take a bite and settled for engine temp, EGT temp and coolant level sensor. Most important to me was that alarms can be preset and alarm is sounded when parameter is out of bound. And there is non-intrusive capacitance sensor for coolant level detecting.
This is how re-programed gauge looked like:
And installed:
I have yet to install EGT probe - some drillling required so must mentally prepare myself Smile Smile At the moment EGT probe is resting in the engine bay straped to the wing and just measuring air temp.
Finaly - I cannot stress this enough - I had realy good experience with the seller (have no connection whatsoever with). Great communication, prompt answers, detailed technical infos, they sent me picture of reprogramed gauge and gave me an option to rearange icon & digit position or change colours.
All I need now is a long holliday trip.
Post #908536 19th Jun 2021 12:35pm
rsms
Slovenia
Here are some more installation details.
Engine temp sensor location - I choose a bolt near original coolant temp sensor. I have not done any long trips yet but the gauge shows arround 83 - 85 degrees C after some 30 minutes drive. Does that look ok? I have no access to Nanocom or similar so cannot check gauge readings vs ECU data.
I have put coolant level sensor just below cold level mark and it will signal coolant loss if coolant level drops cca. 2,5 cm. Sensor cables are routed above coolant tank and zip-tied to return hose to prevent sensor from falling down (gravity related). I used strong two-sided tape to just temporary fit the sensor in place (keep it close to coolant tank) and test everything but after two weeks everything is still firmly in place. I will check if I can put two sided tape directly between sensor and coolant tank to tidy up the installation a bit.
I am still waiting to receive NPT 1/8 tap to be able to install EGT probe.
Post #910356 1st Jul 2021 9:21pm
HenrikSw
Sweden
Thanks for the comprehensive information, always appreciated when someone take the time to share their experience.
Madman including the sensor kit is very expensive in my view, alternatives are welcome.
Please keep us updated on any news and experience. Thumbs Up
Post #910458 2nd Jul 2021 12:04pm
