![]() | Home > Maintenance & Modifications > Best adhesive for headliner? |
EVO stick Trade stuff, I think its the 528 contact adhesive its fecking lethal but it works. A few chums have used it on car projects over the years.
zippo87 Member Since: 29 Mar 2019 Location: Moray Posts: 100 ![]() ![]() ![]() |
I second 528 - I sprayed it on a thinned down through a 2.4 nozzle (I think). The headliner has even had a good soaking through the year, and hasn’t deteriorated its adhesion in any way.
iforland Member Since: 27 Mar 2021 Location: redditch Posts: 17 ![]() ![]() ![]() |
I also agree...but once on it will not come off so no second chance
MichaelE Member Since: 18 Jan 2020 Location: Crawley West Sussex Posts: 155 ![]() ![]() |
I believe that it has to be a high temp contact adhesive due to the heat that comes through the roof during summer [or what summer we get]. I've got a 110 with part of the roof unlined [it's on the list of things to do] and it does get quite hot to touch at times.
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 156 ![]() ![]() |
I have used ebay item number eBay Item No. 113820316737 to fix all manner of carpet and soundproofing in my CSW. It gets my vote and if the (standard) dodgy vinyl headlining starts to lose its grip on the fibre moulding and droop in mine the same as happened in its predecessor I've already decided to use it to stick it back. Cheers, Guy.
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 ![]() ![]() |
Ambersil HS300, use it on everything I want to stick together, added bonus is it's cheap
