Home > Technical > Reverse switch loom connector location |
rherl Member Since: 22 Mar 2012 Location: Utah Posts: 8 |
I think I found the answer. Looks like it comes off from the engine harness and not the bulkhead loom. Looks like I'll need to make my own.
2nd Jul 2021 4:48am |
I'm not sure if this helps but here's a picture of the reverse light switch connector on my 13MY Defender, which I took when I had to replace a failed switch. None of the colours match what you've suggested, I'm afraid.
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
2nd Jul 2021 6:11am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6633 |
On a 2.4 it's on the engine loom, on a 2.2 it is on the main bulkhead loom. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Jul 2021 6:15am |
Thanks for the help. Martin, I ordered 2 of your TD5 to Td4 adapters. I will use them to make the connection back to the fuse box and to the reverse lamp.
2nd Jul 2021 3:41pm |
