Home > My Defender > What Did You Do In Your Defender Today |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1862 |
Truck looks great, but personally I am not at all sure about the footwear Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
30th Jun 2021 4:21pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
Click image to enlarge A pair of somewhat crusty “tube connecting” (3rd row seat belt anchors) were removed recently. Collected today from shotblasters, then dropped off locally for hot dip galvanising. The smaller item is an underbody bracket for an MSS cubby. There are two threaded bosses on the anchors. One is M8 x 1.25 and the other is M11 x 1.25 which appears to be a common size for seat belt fasteners. Here they are after blasting. Click image to enlarge |
30th Jun 2021 6:35pm |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
I've only got the one new battery which is the: ODYSSEY PC1500DT I'll change the primary when it dies which will also give me some more room. Couldnt bring myself to buy two new batteries financially when I need to paint my flat as well. All complete today. Difficult to see the detail as ever but it all works!!! Click image to enlarge Defender 90 XS TD5 (03 Reg) |
30th Jun 2021 8:23pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17443 |
Seatbelt fasteners are normally 7/16" UNF (20 tpi).
If you measured one with a newfangled metric device you'd find it was 11.112 mm major diameter and 1.27 mm pitch. It is almost certain that this is what you have, especially since M11 is a non-preferred size in the ISO standards and there is no definition for an M11 x 1.25 mm pitch thread. |
30th Jun 2021 11:36pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20444 |
See Blackwolf - info like you have just provided is why you are seen as by many including myself as a forum expert and you are a valuable member here.
A true asset to the site that Martin runs so well, if only every member was as level headed and helpful it would make the site even better. (Which it always has been pretty good overall). No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
30th Jun 2021 11:48pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
^^ ^^ 1999 Defender TD5 110
1st Jul 2021 8:20am |
Wow, thanks guys!
1st Jul 2021 9:01am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10782 |
That is great news db950 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
1st Jul 2021 8:01pm |
Collected my freshly blasted and powder coated rear ARB and refitted it along with new bolts, clamps and bushes.
The old bushes had a slight oval to them. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
1st Jul 2021 9:21pm |
Fitted the carling switches and got them to light up when the sidelights come on. Defender 90 XS TD5 (03 Reg)
1st Jul 2021 10:16pm |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 560 |
Cheers Clayton. I’ll post an update on my thread! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
2nd Jul 2021 8:32am |
Keeper. Clayton. |
2nd Jul 2021 7:30pm |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
Over the weekend I installed a dual battery system using the Nakatenenga battery holder, Cyrix-ct VSR, HBC dual battery monitor, and two Varta LA80 AGM batteries.
Today is output shaft day... No idea the condition of my factory shaft (50k miles), but since it had to come all apart to check, a LOF one-piece shaft is replacing it. Roaming around 🇳🇴🇨🇭 |
12th Jul 2021 6:03am |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Agree totally about Blackwolf always patient and helpfull with newbies (most of us were at some point)and i dont think ive seen him tell a poster to use the search function rather than answer the inquiry .I wonder if martin could set up a old timers hints and tips sticky to rival the what you did in your defender today thread..you could have handy tools ,hints and tips ,short cuts ,bolt sizes aand much much more . I know the experienced poster might say the search function is the newbies friend ,but i found it a broad brush tool and a handy hints section might help folk with the defenders idiosynchronicities. Last edited by nitram17 on 12th Jul 2021 4:14pm. Edited 1 time in total |
12th Jul 2021 11:02am |
