Home > Technical > TD5 110 fuel tank breather pipe - Specs |
Hi folks. Windeing if one of you good people can help me out.
I have sprung a leak from a perished/sliced fuel tank breather pipe. Must have been a sharp stone as it is sliced lengthways along the pipe. Had the water in fuel filter light flash on the other day after a ford crossing, investigated and found the split Anyway. Does anyone know off the top of their heads what the internal and external diameters are for this pipe, please? Part number: LR018261 https://www.lrparts.net/lr018261-defender-...-part.html £53 ex VAT for a bit of pipe and a one way valve... Not a chance Also thinking of extending the breather beyond the wheel arch. Any ideas of a suitable place?! Many thanks in advance. |
30th Jun 2021 10:34am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17374 |
IIRC it is 6mm bore or thereabouts. I extended mine up into the rear buck adjacent to the RNS light cluster, but this might not be such a good idea if you have a station wagon (mine's a double cab).
You certainly should move it, Landrover could hardly have chosen a worse place to terminate a fuel breather! I used a length of the type shown below, it's been in place for years and has already lasted several times longer than the overpriced original: Click image to enlarge |
30th Jun 2021 11:00am |
The flexible rubber pipe. |
30th Jun 2021 11:43am |
Many thanks black wolf. I take it the 6mm refers to the thinner bore pipe post one-way valve? I did think of the same location to terminate as my rear diff breather ends there, but like you suggest I have a SW and the potential for fumes may not be a good idea |
30th Jun 2021 11:45am |
It is the thicker pipe I remember as being 6mm bore or thereabouts, this is thickwall rubbery hose. The hard nylon pipe is thinwall and is fitted inside the thicker pipe at the outboard end.
I ditched the roll-over valve altogether and fitted one of the old fashioned throw-away fuel filters (image below) into the line instead, just to keep any dirt out. The filter, plus about two feet of coiled up spare breather is secreted behind the cover that protects the back of the light unit inside the tub. The reason for leaving two feet of extra length is that the 2.4 Puma doesn't have a pump in the tank, so there are situations when bleeding can be a problem. The extra length means that I can very easily pressurise the tank with an airline or in extremis by blowing down the breather if I need to bleed. The tank filler cap incorporates a pressure release vale so you cannot blow the tank up with an airline, by the way. Click image to enlarge |
30th Jun 2021 12:29pm |
Evening Gents. Many thanks for your help, appreciated. Time to order some pipe…
30th Jun 2021 8:09pm |
