Home > Puma (Tdci) > Tips on removing visco fan
Niels906
Netherlands
Evening all,
I'm trying to remove the visco fan on my 2007 2.4 tdci Defender Puma, in order to replace the brake vacuum pump. Problem is, I can't seem to loosen the fan? I tried the trick with the hammer and the spanner, but it's just too tight. Any tips or ideas?
Also is it really necessary to remove the fan? The service manual seems to leave it on, but takes it away for purposes of clarity (page 191).
Thanks all for your help!
Post #910048 29th Jun 2021 7:55pm
90 Dreamer
Can't answer your questions but this thread has a tool pattern......
https://www.defender2.net/forum/topic79154.html
Post #910050 29th Jun 2021 8:00pm
ickle
I always use a SDS hammer drill, on hammer only action with a blunt chisel - a very quick zap on the edge of the nut (no locking tool required) and it spins off - leaving the nut virtually unmarked!
Trust me I'm a doctor - (not really)
Keith
Post #910051 29th Jun 2021 8:01pm
You usually need to hold the pulley with a pin spanner or similar when you remove it since it has probably been massively overtightened in the factory. When you reassemble use anti-seize and don't overtighten, and you should have no future problems.
You don't have to remove the fan for a vac pump change though it makes it easier. You will need to remove the serpentine belt and that requires unloading the tensioner, which is easier with the fan off. It is however possible using a 3/8" sq dr extension bar between the fan blades with the fan in place.
Post #910070 29th Jun 2021 10:02pm
Keith
Shocked Shame on you Sir! A chisel on a nut! Tut, tut. Rolling with laughter
Post #910071 29th Jun 2021 10:04pm
