Home > For Sale & Wanted > [Wanted] To buy or borrow - Puma axle hub
Gasket
Hi everyone.
I'm looking to do a bit of experimenting with wheel stud sizes - have a good selection here along with some Wolf, standard steel and Boost rims.
Rather than dismantling my daily driver 90, I'd love to buy or borrow a loose hub with studs so that I can play with standard steel, alloy and Wolf rims all torqued up to find the best compromise of stud length to suit all three. I have three lengths of stud here now: 39, 45 and 56mm and suspect that the 45mm will be perfect for all three sets of wheels but that the plain shoulder would be too long for the thin steels to properly engage. If that's the case, I'll measure up and will order a custom set prior to changing them with the brake discs (this is so that the stud protrudes slightly through the nut - unnecessary but weirdly appealing).
The hub has to be from a known Puma 90 or the front hub from a 110 - I'll need to know what year it came from as there are two part number listed: FTC0942 and RUB500240 for pre and post VINs 7A777665 (which is really confusing as the format of my VIN is 7AA123456 (double A).
Happy to cover postage if buying or postage and return postage if borrowing.
Thank you for enabling my geekery.
Post #910012 29th Jun 2021 5:08pm
