Home > Puma (Tdci) > Crossmember captive nuts and clearance for spreader plate? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3409 |
I can possibly answer your last question (I opened up one rear cross member from Td5, which is same as Puma).
There are no anti crush tubes. If I remember correctly, the captive nuts are square nuts welded internally (probably more tack welded). These are welded to what is like a spreader plate, about 5" to 6" wide, and not to the external skin of the cross member. This 'spreader plate is welded to a smaller internal channel, which can be partially be seen through the squarish hole. The skin of the cross member is a U channel that is welded at the top and bottom of the smaller channel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
29th Jun 2021 1:12pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17344 |
If you haven't already done so, take a look at the pictures on the second page of this thread. They will answer many of your questions.
29th Jun 2021 2:01pm |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
H both - that's really helpful, thank you! I hadn't found that thread in my search.
29th Jun 2021 6:01pm |
Ah… bit of an issue.
Have just got back home, earlier than planned, and couldn’t wait. Armed with a torch ive just been under the back of the 90. It’s difficult to measure accurately with the tank support plate in place but the distance from the back of the crossmember to the plastic fuel tank is just over 20mm. Now the issue is fitting a nut into that gap: a full-sized nylon m16 nut (type p) is 18mm thick. A thin m16 nut is 16mm thick. Add a little extr for a thread or two sticking through and you’re up to 17.5mm or 19.5mm. Then you need the spreader of between 5 and 10mm. And you need a sensible clearance before the tank to allow for vibration. I don’t think it can work unless I had a recessed plate welded in effectively replacing the back wall of the crossmember. . The only thing I can think of is to make the spreader plate from 5mm steel. Then pass the bolts from the inside of the crossember to the outside - through the crush tubes, with the nuts on the outside of the vehicle. I could tack the bolt heads to the spreader plate so the whole assembly (4x bolts and spreader plate) passed through the crossmember in one hit. As a m16 bolt head is only 10mm thick… add a 5mm plate and that’s 15mm - leaving 5/6mm before the tank but it’d look a bit odd and there wouldn’t be much clearance at all. Think I’m going to end up with a whole NAS step just to get a recovery point here. |
29th Jun 2021 11:11pm |
