![]() | Home > General & Technical (L663) > L663 110 distance between roofbars |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Even the distance between the midpoint of the little locking cutouts on the roof rails rather roof bars would do. Just trying to see whether my existing bike rack is going to work or not.
Thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
I took my crossbars off a couple of weeks ago but there are several options for fitting them - shorter distance between them or longer distance between them…… you might have to enlarge this photo too see the three mounting slots.
![]() Click image to enlarge Here’s a picture with them in the front and middle mounting slots when I had them on the car ![]() Click image to enlarge Which positions do you need the dimensions for? Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Hi Tim
Thanks for your reply. I thought there was only one configuration for the roofbars based on the 2 smaller cutouts on the inside edge of the roof rails. I picked that up from this link section 10 .. http://accessories-instructions.landrover....r/G2409809 If you could measure the roof rails between the midpoint of the smaller cutouts on the inside edge of the roof rails that would give me the answer and be really helpful .. thanks for your help on this. Regards Phil 2008 Defender 110 XS SW - M57N2 / 6HP28X |
Having fixed points for the cross bars seems really odd as I'd have thought the whole point of the roof rails that the bars can be fitted anywhere along their length, if the width is suitably adjusted. That's certainly the way they work on a Discovery and RRS. Darren
That’s exactly what I thought, but the fitting instructions indicate they have only one fixed place, same with this video ..
A bit disappointing as depending on the load you might want to spread them out a bit. I want to use my existing 2 part cycle rack (fork mount and wheel mount) so the distance between the bars is pretty important for this to work. 2008 Defender 110 XS SW - M57N2 / 6HP28X |
Centre to centre of the small cut outs is 700mm, also my apologies, there is only one mounting position as there is no small cutout behind the rearmost slot
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Hi Tim .. that’s great, thank you very much for your help.
Andiamo Member Since: 08 Aug 2020 Location: South Carolina Posts: 6 ![]() ![]() |
I suppose if you get the ones optioned at the dealer you’re locked into just a few locations for the roof bars. I just ordered the parts from Thule myself. I like the look of mine better as well plus I can place the bars at any location along the tracks. |
That’s not a bad idea .. please can you share the parts you used? 2008 Defender 110 XS SW - M57N2 / 6HP28X
These are the parts I ordered:
Thule 3040 Fit Kit Thule 753 Rapid System Foot Pack Thule Wingbar Evo 127 (50 in) Found the idea in this thread: https://www.defender2.net/forum/topic74903.html |
That’s great .. thank you 2008 Defender 110 XS SW - M57N2 / 6HP28X
