Home > In Car Electronics > Wiring Rear interior light
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
Hi All, First post here and its going to be a boring one Neutral
I have a TD5 90 Hardtop and I'm in the process of installing the headliner and plastic surrounds, as well as a rear interior light.
Now, I bought a rear loom but appear to have a few things missing and so I am now lost and confused.... Rolling with laughter
I've currently got sat here the rear light with bracket and rear loom w/ the curtesy switch but not the link I need however my car doesn't have the immobiliser and ultrasonic sensor so does this mean I need to do some custom wiring to get the rear light to function?
I don't see how the rear light is fed power, am I missing something out entirely
[/i]
Post #908335 17th Jun 2021 4:07pm
donmacn
My car is a 300tdi era so not dirctlyy comparable but.....
Are you saying that you had none of these things in the car before - headlining, trim or rear light? Do you have the courtesy light switch on the rear door frame - about the level of the rear wheel arch/where the heated rear window loom goes into the car?
In the Tdi vehicles, the power to the rear light goes via the push/courtesy switch, and then is earthed to the bodywork.
If you don't have the switch, and want the light to come on as the door opens, then you'd need the switch too.
If you just want a light that's manually switchable, you'll just need to tap into one of the wires behind the light cover - either ignition swithched or permanently live.
(Edit - PS - welcome to the forum!) Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #908348 17th Jun 2021 6:19pm
Yes, you'll have to do a bit of custom wiring, I'm afraid. It's not difficult, though - tee in the three wires to the light into the existing wiring and extend the earth wire to the new rear door switch. The hardest part when doing this sort of thing is making the connection to the new light but if you have that bit of the loom with the proper connector on then you don't have that issue.
It's not a direct comparison but I added a third light to my 110 by splicing in the three wires (earth, constant live and switched live) to the existing loom:
It's worth noting that the way the lights operate on your TD5 are different to what Donald has described on his tdi - on yours the light is earthed by the door switch.
I hope that helps. Darren
Post #908384 18th Jun 2021 5:27am
grafty99
If you get the correct loom it should just plug in above the driver side A pillar Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #908390 18th Jun 2021 6:36am
dorsetsmith
Grey plug above the driver side A pillar C0259---- pin 1 ----- Black wire------ B------------ battery -
--------------------------------------------C0259-----pin 3----- Purple white-----PW--- interior light control for alarm unit
--------------------------------------------C0259-----Pin 2-------Purple Brown -----PN------- fuse dc+
you will find pin 1-2-3 in this grey plug have wires in place ,interior light are wired in parallel
Post #908414 18th Jun 2021 10:28am
I should probably add that my suggestion of splicing in the wires was on the basis that you said you don't have the required link wire to the existing harness. If you can get that wire and just plug it all in then that would be the preferred option. Darren
Post #908417 18th Jun 2021 10:52am
LJMARSDEN
Don't worry mate I got what you were suggesting Thumbs Up
Post #908422 18th Jun 2021 11:13am
LJMARSDEN
I'll order the next loom which is refered to as a "lead - link" and then I'll have a gander for the extra plug on the front loom and see if my 90 has it - only questioning whether it will or not since its a low spec vehicle.
are you grafton on Instagram? You've got a clean TD5 pal
Post #908423 18th Jun 2021 11:21am
grafty99
I think fitting the wiring harness is the best option if the plug is there.
Thank you, yes that's me @george_grafton Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #908944 22nd Jun 2021 12:27pm
LJMARSDEN
So I just recieved AMR4991 and removed the headliner partly to find the grey plug you mentioned george.
Now, I might be being a bit dim but I cannot find any where to plug in this loom at all
Post #909140 23rd Jun 2021 4:35pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
looks like you are missing the metal backing plate that the single black wire clips into. It has 2 studs that pass through the light assembly and are held in with 2 nuts. part# 3 in the diagram in a posting above. it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #909509 26th Jun 2021 6:26am
dorsetsmith
I cannot find any where to plug in this loom at all . as you have early type rear interior light loom with round pin connectors you will need to splice the wires to giver on this side
Grey plug above the driver side A pillar C0259---- pin 1 ----- Black wire------ B------------ battery -( to black on your loom)
--------------------------------------------C0259-----pin 3----- Purple white-----PW--- interior light control for alarm unit ( purple -blue tracer on your loom)
--------------------------------------------C0259-----Pin 2-------Purple Brown -----PN------- fuse dc+ ( to purple on your loom)
As you have early type rear interior light loom with round pin connectors wire colours may not match between the early and later wiring see below
Black wire pin 1------ B------------ battery -( to black on your early loom)
Purple white pin 3-----PW--- interior light control for alarm unit ( purple -blue tracer on your early loom) or door switch only
Purple Brown pin 3 -----PN------- fuse dc+ ( to purple on your early loom)
Post #909517 26th Jun 2021 8:25am
dorsetsmith
Wiring Rear interior light with no alarm ecu
Post #909525 26th Jun 2021 9:37am
LJMARSDEN
Thanks for all the info Dorsetsmith - I'll let you all know how it went once a few more parts have arrived and I get to installing it all.
Post #909728 28th Jun 2021 5:25am
LJMARSDEN
Little update = I found the time to begin the wiring and I got the light to run off of the original and the front courtesy switches.
Am I right in thinking I have to splice the 3rd courtesy switch into the earth in the plug above the drivers seat?
And would that be Pin one like you said
Post #911915 11th Jul 2021 1:16pm
