Home > Maintenance & Modifications > ABS conversion / retro fit
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Hi all
Considering retrofitting ABS and therefore traction control to my 2006 model year TD5 130.
I know this was never a factory option in the 130 but does anyone know why? The ecu and valve block is the same between 90 and 110 so can't see those wouldn't work - the only thing I can think is that the rear sensors will need the wires extending somehow.
I've bought all of the wiring/ecu/servo/master cylinder/valve block just not the axles yet as was hoping for some complete with sensors etc that I can just swap out.
Ben
Post #908862 21st Jun 2021 9:48pm
Linds Hanson
Should work just fine but be careful with used modulators they aren't the most reliable particularly on vehicles that stand around and don't get regular fluid changes
Post #908906 22nd Jun 2021 9:03am
geobloke
Re: ABS conversion / retro fit
benspray wrote:
Hi all
Ben
Hi Ben. Often thought of doing the exact same thing with my 2003 110. Where the heck did you find all the wiring from?! Good plan to do the mod though.
Plan B for me is the fitting of Ashcroft ATB diff centres as a mechanical alternative.
Looking forward to your install Smile
Post #908911 22nd Jun 2021 9:10am
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Think Ive got a webco ecu if anybody needing one Thumbs Up
Post #908912 22nd Jun 2021 9:17am
benspray
Cheers guys
yep re the wiring I bought an "XS" spec fully loaded bulkhead/main loom with ABS etc included - YMC500863 that contains everything you need and plugs straight into the sensors on the axles (albeit I'm assuming the rears will be 17 inches short for a 130 lol).
Not looking forward to the loom swap though but will allow me to fit heated windscreen/heated seats, electric windows central locking etc to my previously poverty spec 130 Smile
Initially I was looking for a YMC500903 loom which is the XS spec minus ABS but this one came up at a reasonable price and given the 130s tendency to instantly lock the wheels up in the wet I though it may be worth it.....
ps I do have another loom here YMC500872 which has ABS but no heated seats/windscreen that I may have up for sale at some point.
Regards
Ben
Post #908921 22nd Jun 2021 10:02am
benspray
if anyone has any scrap rear ABS sensors I'd be interested to cut the wiring off and see how easy it would be to make a short extension out of them Smile
Post #908922 22nd Jun 2021 10:03am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
It just so happens I have a pair of rear sensors sitting on the shelf Thumbs Up 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #908923 22nd Jun 2021 10:07am
bankz5152
You can buy Wabco extensions off ebay.
https://www.ebay.co.uk/itm/WABCO-TRUCK-ABS...890.l49286
It would be worth changing the shuttle valve before fitting the modulator and potentially doing the wiring mod at the same time. Reduce any future issues. Instagram @defender_ventures
Empire Tuning - Agent
Post #908931 22nd Jun 2021 10:41am
benspray
Didn't really think that ABS extension wires would be an off the shelf thing but pretty handy Wink
Post #908963 22nd Jun 2021 2:57pm
I believe that they are used extensively on HGVs.
Post #908967 22nd Jun 2021 3:43pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
No need to look for old ABS sensors as a wire source. The wire from sensor is just a pair of twisted wire in secondary rubber cover. I have repaired several broken wires, replacing parts of them with hand twisted two FLRY wires and covering them in heatshrink tubes.
Using old wires is not the best idea, they can crack because of their age and previous use.
I had the same idea, retrofiting ABS to 130, but I have to renovate the car first. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #909030 23rd Jun 2021 5:50am
Linds Hanson
The shuttle valve is just one of many issues that cause modulator faults, out of all vehicles D2 and Defenders appear to have more than average modulator faults
Post #909046 23rd Jun 2021 8:05am
glpinxit
Just on 'keeping TD5 ABS working'. When I had mine, I used to plug my Nanocom in periodically and run the pump once for each corner. If I didn't do this it became sluggish (and always speeded up noticeably as I worked my way round the corners). Cheers, Guy.
Post #909073 23rd Jun 2021 10:37am
