![]() | Home > Td5 > Chattering fuel pump relay |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 959 ![]() ![]() ![]() |
As you suspect possibly a ground (earth) issue have look at the ground wires to the relay plugs and inside the under seat compartment. Also check voltage to the relay plug itself.
![]() The alarm horn sounding, check your bonnet switch up by the bulkhead. Common failure point. Plastic plunger breaks or the bracket just needs a slight bend upwards. Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Shuggy110 Member Since: 25 Mar 2018 Location: Perthshire Posts: 58 ![]() ![]() ![]() |
Thanks - will do. I don't have a bonnet switch as I'm not sure I have an alarm - just the green immobiliser box behind the instrument binnacle.
I'll look under the seat and will check the fuel pump relay ground... I guess bonding it to the bulkhead bolts would be a sensible test. Cheers. |
Pretty sure they all had a anti theft set up with a bonnet switch. 🤷♂️ Look for something that looks like this.
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
green immobiliser box behind the instrument binnacle. and the alarm ecu all in one unit, bonnet switch may be fitted or not and how the alarm and immobiliser ecu is programmed will dictate witch add on parts all work but bonnet switch all work with out programming
A quick update. I definitely don't have a bonnet switch. It is a very early Td5 built by Special Vehicles for the National Trust. That aside, the chattering has stopped for now. I'd like to think that cleaning up the earth and the ECU plugs and sockets has helped but I'll come back and report again if it changes.
