![]() | Home > My Defender > hanks Double Cab |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2317 ![]() ![]() ![]() |
It was long enough yes... Just!
I ran it down the side of the dash centre console, under the carpet and over the front seat box, then through the floor at the top/rear of the seat box just in front of the seatbelt receiver bracket (shown circled red). Then it goes under the rear floor and back into the cabin at the rear of the sub to be plugged straight in. I used a depinning tool from amazon to remove the sub connector molex plug in order to keep the holes in the floor as small as possible. Also fitted grommets Can get some proper photos on the weekend if required, until then I have the following... ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab |
Tonser Member Since: 08 May 2020 Location: Surrey Posts: 77 ![]() ![]() |
Thanks Hank, that's perfect. I may well follow your lead(s) !
Cheers Tony |
Let me know how you get on
Black sun visors sourced/fitted to complete the black headlining/interior change
![]() Click image to enlarge And of course an obligatory snow photo ![]() Click image to enlarge > 110 XS Double Cab |
New brakes built up to fit all round...
Would really like to fit a Pioneer 4x4 complete hard line replacement kit but they don't seem to list one for TDCi / ABS. Will have to contact them. Looking forward to fitting these when the weather breaks Fronts Low mile 'take off' AP Delphi calipers lacquered with high temp lacquer Stainless pistons AP Delphi pads AP Delphi fitting kit (pins, anti-rattle springs, spreader springs, clips) AP Delphi discs Rears Brand new AP Delphi calipers lacquered with high temp lacquer Stainless pistons AP Delphi pads AP Delphi fitting kit (pins, spreader springs, clips) AP Delphi discs ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab |
Defender developed a squeaky aux belt recently so seemed time for a new one. 80k on the original LR belt which I thought was reasonable
Nice easy job, was half expecting it to be a pig Whilst I was there I removed the idler pulleys and tensioner and repacked their bearings with grease as they had gone a bit dry. Also cleaned/degreased all pulleys and rolling faces Nice squeak free running ![]() |
It had sometimes confused me why I couldn't get my sidelights to illuminate on their own.
From the forum I came to learn of the dim/dip "feature" and was keen to remove/bypass it There are a few ways to do it... unplug engine bay connector, use jumper wire, fit LR bypass relay YWZ10003L (£30!!) but I decided to modify the existing relay. Some steps should anybody else want to do this... Remove the big pink relay from the board under the steering wheel and unclip the cover from the base Cut/desolder/remove everything but the two necessary pins - these are the two that remain on the left hand relay below ![]() Click image to enlarge ![]() Click image to enlarge Jump these pins ![]() Click image to enlarge Success ![]() Click image to enlarge > 110 XS Double Cab Last edited by hank on 15th Dec 2022 10:58am. Edited 1 time in total |
I managed to source a bigger GT2256 turbo from a 3.2 TDCi
Externally it looks to be physically very similar to the factory 2.4/2.2 GT2052. Manifolds are the same, same hole centres, bores etc. Turbo outlet diameter is the same etc. Plan is to build a Hybrid turbo by fitting the 56mm compressor side from the 3.2TDCi GT2256 to my 2.4 original 20mm hot side resulting in a GT2056 The 3.2TDCi GT2256 has a six blade compressor wheel vs the factory five blade Below are some side by side comparison photos. 3.2TDCi GT2256 left, 2.4/2.2TDCi GT2052 right ![]() Click image to enlarge 3.2TDCi GT2256 left, 2.4/2.2TDCi GT2052 right ![]() Click image to enlarge 3.2TDCi GT2256 ![]() Click image to enlarge 3.2TDCi GT2256 ![]() Click image to enlarge 2.4/2.2TDCi GT2052 ![]() Click image to enlarge 2.4/2.2TDCi GT2052 ![]() Click image to enlarge > 110 XS Double Cab |
Hybrid turbo built up and fitted and initial impressions were not great! But Pete Bell provided me a tweaked map to provide the extra fuel required to match the extra boost and it really came alive. All in all a good outcome, especially considering the new turbo was under £100 and only took a couple of hours to fit. To be completely honest though not worth it if you're looking to pay £1000 for a hybrid turbo
The below image shows the standard 52mm turbine wheel compared with the larger 56mm one ![]() Click image to enlarge And the same again with the associated seal plates ![]() Click image to enlarge Inside of the 52mm and 56mm compressor housings ![]() Click image to enlarge Factory turbo with the compressor housing removed ![]() Click image to enlarge Compressor wheel removed ![]() Click image to enlarge Seal plate removed ![]() Click image to enlarge 56mm seal plate refitted ![]() Click image to enlarge 56mm compressor wheel fitted ![]() Click image to enlarge 56mm compressor housing fitted ![]() Click image to enlarge Fully assembled ![]() Click image to enlarge > 110 XS Double Cab |
New AP Delphi front callipers fitted with stainless pistons, new JLR rigid brake line, new AP Delphi discs and AP Delphi pads fitted
![]() ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab Last edited by hank on 18th Jun 2021 3:49pm. Edited 1 time in total |
Seams to be leak week
- Leaking AC condenser. Replacement sourced from https://www.ebay.co.uk/itm/363436234249 - Leaking intercooler (Alllisport). Replacement sourced from BAS - Leaking heater control valve. This will be the third replacement I have fitted. Went for a genuine JLR part this time rather than the cheaper ones available online - Oil leak spotted underneath... Not sure where it's coming from yet. Have degreased in an effort to better locate the source. Possibly sump gasket or a PAS hose union. - Cash leaking from bank account. Source suspected to be Land Rover Defender ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab |
Love the dark interior. It’s one of the less technical modifications I’ve done but it's easier on the eye
BAS intercooler is in. First impressions… Immediate obvious difference in power. The turbo still spools up the same but since the boost is actually getting through to the engine now rather than spewing out of the split intercooler the engine picks up immediately and comes on song nice and low down in the revs then pulls right through the rev range. I’m not saying the BAS one is better than the Allisport, just saying that having the pressure side of the intake system sealed is a definite bonus ![]() ![]() Click image to enlarge Also fitted the new heater valve complete with cold temp return spring mod… Works a treat ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab Last edited by hank on 16th Aug 2023 11:47am. Edited 1 time in total |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10894 ![]() ![]() |
Great work going on there Hank, liking the new intercooler
![]() I too had the same problem with my Allisport intercooler developing 2 holes like yours, as you had more of a choice other than Allisport i was not so lucky but in the end i found Airtec and had the choice of colour ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2194 ![]() ![]() |
Tbf after 3 years in mine my Allisport popped as well, though they replaced it within a few days of reporting it so cant complain!
Good to know about the darker interior. I dont think ill bother trying to recover it, experimented on my 90 and it didnt go well ![]() So dying/painting is a better option! What did you use? Instagram @defender_ventures Empire Tuning - Agent |
