Home > Puma (Tdci) > Defender 2007 Puma oil leak
Niels906
Netherlands
Good evening all, my new to me Defender runs great, but it has an issue with oil being sprayed on the inside of the bonnet. Obviously this can't be a good thing, so I'm trying to figure out where it may come from. Any ideas from you lot who know a lot more about Defenders than I do? Photos in the gallery.
Thanks!
Niels
Post #908467 18th Jun 2021 6:18pm
Usually an oil spray onto the underside of the bonnet of a 2.4 Defender (especially a 2007) is caused by a leak from the vacuum pump. There are several threads on the forum about this problem.
Post #908471 18th Jun 2021 6:55pm
Niels906
Netherlands
Thanks
Thank you for your help. After reading up on it, this seems the most likely cause, I’ll order the parts tonight. Thank you
Post #908480 18th Jun 2021 8:09pm
Niels906
Netherlands
Sortof fixed it
So I replaced the brake vacuum pump, which has sorted the issue, i think. Only problem now is a sort of zinging noise which wasn’t there before, so I must have done something wrong…. But other than that, replacing it was fairly easy… Just that annoying brake vacuum pipe. Nightmare to get it off, but figured it out in the end. Just pull and keep on pulling.
Post #910502 2nd Jul 2021 6:57pm
AndyS
You've got to push the collar in while pulling the tube out. That fitment is common on printing presses which is how I knew what to do. It's a clever design but takes a bit of head scratching to figure out.
Post #910513 2nd Jul 2021 7:45pm
