Home > Td5 > Oil Pressure light / Oil Pressure issue |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5700 |
Definitely need to get a pressure gauge plumbed in to see what is going on. How many miles on engine? Good quality filters?
18th Jun 2021 2:12am |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 208 |
Thank you for your reply.
I'm just over 160,000. I always use good oil and filters. Normally shell oil and MANN filters. I will order a kit to measure pressure. |
18th Jun 2021 11:05am |
I have tested the oil pressure and all seems fine.
I replaced the oil pressure switch and it behaved normally for about a week or so. Oil pressure is 3+ Bar cold idle and 5+ bar cold. I fitted my Roof tent this weekend and went to move it today and oil light on I was planning all the mods and adventures to have in the Land Rover last night and today back to broken Double checked and pressure is fine..... So I'm assuming wiring/electrical fault. I could not see any issue with the wiring from what I could see but it's inside a plastic conduit over the gearbox. What would you suggest? Should I replace the wire back the the plug under the seat with a new one? Any other suggestions. Thank you! |
5th Jul 2021 1:18pm |
It’s not a problem I’ve come across before, but I would run a temporary wire and see how that effects things.
5th Jul 2021 8:35pm |
