Home > Off Topic > Swim spa/small pools...
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Hi there,
The better half has a weak back from spinal surgeries, she loves/ needs to swim and we have moved to an area that is severely lacking in swimming facilities.
We recently chanced upon someone installing a swim spa, a 2.5 m by 5 m pool with a swim jet installed and got to thinking..
We have a sloping garden that could be just the ticket for installing this relatively small pool, was just wondering if anyone had installed anything similar?
The good lady is a garden designer, so ideas of natural pools/ filtration are being bandied around... we would install in deck with an insulated cover for year round use. I would be installing.
Alex 98 300 tdi 90 project
94 Range Rover vogue 4.2 lse
79 911 sc
08 130 double cab utility
Post #907619 13th Jun 2021 9:12am
Merlin
This is our paddling pool, 4' x 15', swimming is in circles only:
Peter
Post #907636 13th Jun 2021 11:58am
ickle
We're planning a swim spa, much the same, but potentially in a building for year round use depending on planning.
A natural pool wouldn't allow it to be heated, IIRC you need something like three times surface filtration area to swimming area to keep it clean.
Biggest heat loss is evaporation so a really good insulated cover is a must, for construction look at ICF's. A 4 season heat pump will be needed, still looking at swim jets.
If ground conditions are perfect and construction quality is spot on you can tile, otherwise a liner is safer. GRP pools are starting to get more popular and we did enquire about the welded polyethylene type but they were massive costs with the same transport and crane problems associated with GRP.
The above ground swim spa / hot tub combos may also be a ready made solution - we've had a hot tub for 15 years now still going strong, hot tub in winter and plunge pool this time of the year.
HTH Keith
Post #907927 15th Jun 2021 11:56am
barbel jim
You don’t even need the swim jet. A good friends mother swims competitively and She goes over year round and swims in there pool attached to the side with a piece of elastic Laughing not exactly relaxing but just a thought. She’s that keen she dons a dry suit in the winter Rolling with laughter
Post #908022 15th Jun 2021 7:55pm
