Home > Technical > Steering guard vs. protection bar |
Surely the point of all of this sort of stuff is just an insurance policy? Whilst you could go many years without needing it, there might come a day when something unexpected happens when you do and you'll be grateful for it. It's a bit like those people who say they don't bother carrying a spare tyre because they've never had a puncture in 30 years, when the length of time is irrelevant as to whether there's a nail on the next bit of road they drive on.
In my experience, they come into their own when driving particularly rocky terrain, which obviously isn't so common in the UK. Having said that though, only yesterday I was watching a bit of video of a Land Rover somewhere in the Lake District struggling to get off a lane with its' front wheels pointing in different directions. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
7th Jun 2021 9:17am |
lakelander Member Since: 07 Jan 2017 Location: Cumbria Posts: 100 |
Thanks! |
7th Jun 2021 9:19am |
Looks good and sturdy what brand is it ? |
7th Jun 2021 9:22am |
It's a First Four Off Road one although unfortunately they've recently closed due to retirement. However, there's a very similar one available from Paddocks:
https://www.paddockspares.com/pm1143-heavy...-eyes.html Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
7th Jun 2021 10:02am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
The Paddock one appears to be the Safari Equip (non-receiver) guard, essentially what I have on mine (except I have the receiver version) and if so I can highly recommend it, it is very substantial.
I completely agree, it is, like so much of what we do, a very personal choice. You could fit one and never need it (a bit like a fire extinguisher), or fit one and the next day it saves you from an expensive repair, or even results in an expensive repair. As far as the OP's question is concerned, I don't think that the genuine Landrover "twiglet" is likely to achieve much in any situation however. |
7th Jun 2021 10:37am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
I got the aluminium one from Paddocks. Quite pleased with it, although I modified it to make it look better:
1. Replaced the bolts that mount the plate to the brackets with countersunks. Of course plate needed countersinking. 2. I chopped off a bit from the ends to make it more rectangular. The original shape is too trapezoidal (wider at the front). I cut enough to be in line with the chassis rails. 3. I added spacers between the brackets and the chassis. They do not come with the kit. 4. I painted the galvanized brackets black. Just to reduce the different shades of grey. Have not and not yet planning to get my return on investment Only for looks. https://www.paddockspares.com/pm716-heavy-...ender.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
7th Jun 2021 11:07am |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 632 |
Having had LR OE bar types and both ali and steel guards over the years I have a preference for the bar type with Jates for laning.
Although as discussed they are sacrificial if hit hard, they still do the job and can be hammered back and welded. They don't act like plough in reverse - and having been suction-glued in a trench with the plough making matters worse I have no love for this design. You can also have unrestricted service access from beneath with a bar - that you lose with a guard. Having bashed an ali guard I'd avoid at all costs because it case-hardens on impact and bloody hard to bend back. A steel one would makes more sense in this respect.
We had a tie road bend on Tilburthwaite many years ago - but it wasn't due to a rock strike. The car slipped down an icy slab and the driver applied some lock in fear of going over the edge. The tie rod bent because it was already weakened - having been bent before and straightened with heat. As it landed the shock load bent it again. Moral of the story is to replace rather than straighten steering bars. Click image to enlarge Click image to enlarge Click image to enlarge JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
7th Jun 2021 6:59pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2638 |
If you ever do bend one. You can use the NATO hitch to straighten it out
It’s very effective and much better than the hitting it on a tree method….. |
7th Jun 2021 7:21pm |
Yup, accepted practice with rear x member handles used as braces!
Click image to enlarge Relevant clip at 5:30 - 7:00 ish https://youtu.be/d1WgFyHnEww JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
7th Jun 2021 10:09pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Click image to enlarge The small U shaped support is a real track-rod saver, however I have to admit I used my winch a few times to get it straight enough to drive till the end off the day. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
10th Jun 2021 9:07pm |
Got some forged Jates from Overlander 4 x 4. Jaws have inside width of 90mm but they are just 5mm too narrow to go on over the bar arm! Are they available in different jaw widths? |
13th Jun 2021 2:00pm |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 627 |
I checked my history file.
The ones fitted are from Paddock spares. Part number PM786. The bar was fitted by a garage but the JATE rings do not seem to be modified. 1995 Defender 110 CSW 1971 SIIA Lightweight |
13th Jun 2021 8:04pm |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 717 |
I was thinking of fitting the oem steering protection bar with genuine jates too, but have a question; I have previously fitted jates and done the bolts up b*stard tight only to find under a robust recovery they still pulled round trapping the shackle between the chassis. After this my understanding was you leave the jates loose enough to easily rotate. However as that bolt would also be used to mount the steering bar, you'd probably want it fully torqued up. So, leave loose or tighten up? Instagram: l90andy
2006 Land Rover 90 TD5 CSW Silver Edition My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
14th Jun 2021 7:51am |
A better solution would be to fit different recovery points. Yeah, you can hang your LR from a helicopter but as practical recovery points go they're pretty rubbish. Darren
14th Jun 2021 7:56am |
