![]() | Home > General & Technical (L663) > Is the defender mechanically Better than a Range Rover Sport |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 ![]() ![]() |
According to some of the literature the Defender allegedly has larger and stronger
underpinnings, such as ball joints bushes etc, also compared to our L320 RRS, the other difference is the Deffa also has a twin airbag system on each corner rather than a singular, not sure if this also featured on the later 494 RRS, yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
Having driven a new defender, personally I would find it quite a hard swap from a RRS. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Especially going from any RRS with the Dynamic setting in the TR, Defender can put on a good FFRR roll impression when you start to push it on the twisty bits. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
Interesting! What differences did you mainly notice? I got an 2018 Dynamic Sport and actually looking forward to swap against a new Defender. Yes, I expect more road noise and less ride comfort. Have to admit, the Sport is a fantastic do-it-all car so time will tell where the New Defender falls short of it. m |
GreenMonster Member Since: 30 Sep 2020 Location: Virginia Posts: 77 ![]() ![]() |
What’s your intended use? If you are more concerned about roll and handling on high speed twisties, then sure, stick with the RRS. If you want to do anything truly off road where angles, more robust construction, clearance, more utilitarian interior etc will matter, then you’ll be a lot happier in the Defender.
IRBails Member Since: 25 Feb 2021 Location: Wollongong, NSW Posts: 25 ![]() ![]() |
Some good info here. I am after a tow vehicle and also want the updates. There are no really compelling issues, I have the SVD 8 which has all the Dynamic handling bits. I was just wondering if more features were added?
