Home > General & Technical (L663) > Rust on new defender
Page 2 of 2 <12
Retroanaconda
Mine is the same, rust at the leading edge as well as around the bolts.
Post #907474 11th Jun 2021 8:04pm
MrEleven
Got told today the rust on the heat plate is getting fixed and replaced but only as a good will gesture. So im guessing that means in 6 months time when the new one rusts again don’t come back asking to get it fixed Rolling with laughter
Post #907979 15th Jun 2021 5:14pm
lohr500
Not sure how hot it gets, but could you give it a light coating of something like ACF50 once replaced to try and stop it going the same way again? Sad that such steps are needed but perhaps a little bit of TLC now might help in the long term.
Post #907987 15th Jun 2021 5:44pm
treps
Is rust on the new defender a real issue or is it rare?
I ask as I gave up my old Defender model due to concerns about long term rust... I am about to order a 110 but if this new model also rusts it might not be the car for me. I can cope with annoying but fixable issues such as electronics but I am done with rust and leaks. Very Happy Many thanks.
Post #918479 24th Aug 2021 8:30am
Tim in Scotland
15 months and 11700 miles into ownership the only signs of corrosion on my 110 is one tiny spot on one of the dealer fitted recovery eyes at the back and I put that down to having had to use them last winter to recover a neighbour’s Evoque from a ditch that it slipped into during a snowy spell when I used a metal shackle instead of a soft shackle to attach strop to recovery eye. The recovery eyes don’t appear to have much paint on them - maybe a single top coat with no primers? Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #918514 24th Aug 2021 11:17am
Tim in Scotland wrote:
... I used a mental shackle instead of a soft shackle ...
Telekinesis? Shocked
Post #918520 24th Aug 2021 11:25am
MrEleven
I would say its a problem just because i was told they would fix mine as a good will gesture. To me that says they know its a problem and dont bother coming back when it happens again.
Post #918522 24th Aug 2021 11:34am
J77
Mines only coming up for 6 months old but so far no signs of rust. 24MY 90 D250 HSE, Tasman Blue
Post #918524 24th Aug 2021 11:53am
Tim in Scotland
Now corrected by telepathy………. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #918565 24th Aug 2021 5:25pm
J77
No, it’s everything else you need to worry about Rolling with laughter 24MY 90 D250 HSE, Tasman Blue
Post #918567 24th Aug 2021 5:53pm
Page 2 of 2 <12
