Home > Maintenance & Modifications > Removing powder coating from a galv part. |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 |
Biggest thing is that they supply spacers to fit down the sides and attach between the sliders and the out riggers.
You then drill holes in the end of the outrigger and bolt through. When you fit them as far in at the front as you can, line them up perfectly but discover you'd need at least 3x as many spacers to make them fit properly and look right... It's not you, it's just that they don't supply enough spacers. A quick phone call and they can arrange to send you more. Mind you this was 6 years ago. But yep... That's the biggest thing. |
9th Jun 2021 5:09pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4225 |
Thanks. I’ve got only 4 spacers (that are badly warped for some reason) 2007 110 TDCi Station Wagon XS
9th Jun 2021 6:50pm |
