![]() | Home > Maintenance & Modifications > Optimill Rear Camera: Show me the view! |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
Not really an optimill, but very discreetly installed under the rear plate spacer, and at a fraction of the cost.
When reversing into tight spaces, I use the tow ball as my reference. And it work really well in the dark too. ![]() Click image to enlarge ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Andy T Member Since: 25 Aug 2017 Location: Bucks Posts: 233 ![]() ![]() ![]() |
Just a word of warning, I love the Optimill camera and view is now excellent, though I had to replace my full length Flatdog ladder with a 2 piece one to avoid the view being obscured by one of the rungs
![]() 1998 300TDi Wolf TUM 2015 2.2 Corris Grey 90 2009 2.4 Alaska White 110 Commercial - gone 2006 TD5 Barolo Black 90 - gone 1995 TD5 Green 90 - gone 1984 2.25 Marine Blue 88 |
Peter 110 Galway Green Member Since: 10 Jun 2021 Location: Essex Posts: 4 ![]() ![]() ![]() |
Hello, which ladder do you have? I have the same issue and wondered whether there was an alternative ladder so that I can use the rear camera?
https://www.flatdoguk.com/defender-rear-ladder-%2B-step~1018
This is the one that is compatible with my optimill rear view camera as opposed to the 'full length' version by the same manufacturer ![]() 1998 300TDi Wolf TUM 2015 2.2 Corris Grey 90 2009 2.4 Alaska White 110 Commercial - gone 2006 TD5 Barolo Black 90 - gone 1995 TD5 Green 90 - gone 1984 2.25 Marine Blue 88 |
thanks for coming back so quickly, Andy. It's much appreciated!
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Ive just fitted the optimil unit and whilst im still working out the distances I woulnd still not trust for close up parking because of its offset position and the skewed view at close quarters.If i get time i will do a proper marking out of the image to see how acurate it is ..its fine if you just want to make sure there is nobody behind you if you reverse and you use your mirrors to do most of the work when parking. I used the Mud package .optomil and JVC head unit ..the JVC head unit is small but adequate except for annoying banner stating use your eyes to check that flashes every three seconds or so ..if i had known that i would not have purchased the jvc head unit ![]() Last edited by nitram17 on 10th Jun 2021 7:08pm. Edited 2 times in total |
double post
Bucko Member Since: 21 Nov 2016 Location: West Yorkshire Posts: 43 ![]() ![]() ![]() |
I have the same set up, Optimill reverse camera and JVC head unit and agree completely with Nitram17, although you do soon get used to the offset position. I have the spare wheel slightly in view to help gauge the position but in all honesty I do only use the reverse camera to check for rouge kids and dogs loitering behind, out of view.
I had originally mounted a reverse camera beneath the number plate light plinth but changed to the optimill for a neater solution. Hope the image helps. Nitram17, I’d never really noticed the ‘check surroundings before backing up’ script until you mentioned it although it’s there all the time on mine, it doesn’t flash ![]() Click image to enlarge |
The jvc unit is only three inches so the banner takes up a greater part of the screen as the lettering has to be legible so that's why it flashes as it does interfere with the view when its on the screen and i don't think anybody would put up with it if it was there permanently.
