![]() | Home > In Car Electronics > Split Charging Systems - Installation Recommendations |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
https://www.drive.com.au/reviews/ctek-d250...p-charger/
Take a look at this product : their manual is online - with an option for solar panels that I do appreciate. I managed the installation and I'm sure you'll succeed, too It's plug & play P.S. The winch shall be connected to the starter battery and the alternator because it consumes so much energy. Last edited by Julie on 7th Jun 2021 8:14pm. Edited 2 times in total |
klacinak Member Since: 11 Jul 2019 Location: Kunhegyes Posts: 8 ![]() ![]() ![]() |
Hi,
you can check this: https://adverc.co.uk/collections/adverc-battery-systems Once I installed Tmax for a friend, I do NOT recommend it. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1986 ![]() ![]() ![]() |
It isn’t really that' bad a job to do yourself, i fitted the National Luna kit and it was a doodle quite a nice enjoyable task.
I also fitted the Gwyn Lewis twin battery tray. Worth giving it a try IMHO ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1315 ![]() ![]() ![]() |
Or meet up with someone in your area and perhaps they can help?
I am in Greater London so not that far from you - happy to help you sort it. The battery types (for main and aux) is the first decision. If you want to position both under the passenger seat, then it limits the choice of aux as the space there is tight Re dual battery tray - you can buy or make your own You can also fix the vulnerability of the live feed from battery box to fuse box I went for the Victron voltage sensing relay ![]() Click image to enlarge |
