Home > Wheels & Tyres > Were Sawtooth alloys factory or aftermarket? |
They are a factory wheel, first introduced on the X-Tech special edition but later offered as a mainstream option. Darren
5th Jun 2021 7:22am |
GeeBee Member Since: 03 Apr 2018 Location: Perthshire Posts: 15 |
Thank you! 2012 USW Keswick Green 110
5th Jun 2021 7:36am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2116 |
Mine are genuine , fitted during the build at the factory. On the inside of the wheel the name Land Rover is part of the casting. There are non genuine aftermarket ones, but I expect they don’t have the cast Land Rover name, unless they are counterfeit ones of course.
There are a few threads on here’ regarding sawtooth wheels, showing the different versions available to buy. This was due to people having concerns over the strength and durability of some version on the market. https://www.defender2.net/forum/topic39161.html |
5th Jun 2021 11:26am |
5th Jun 2021 11:50am |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 191 |
I was on the market for sawtooth earlier in the year, so did some research at that time and aggregated the following :
- 18-inch : the only genuine 18-inch Sawtooth is the Diamond Cut one (LR123935), so all other 18-inch Sawtooth alloys that you see are therefore aftermarket ones. - 16-inch : as Ianh says, if genuine, then Land Rover name is casted on the inside. Aftermarket : there seem to be two main aftermarket ones : - the ones distributed by Britpart. They are the thick spoke profile type, load rated 1000k and ET20 for both 18 and 16-inch. Interestingly they appear on Britpart 17th edition catalog but are not to be found anymore in their latest 18th edition catalog. - the ones distributed by Bearmach, 4x4 tyres (and I am tend to believe John Brown Wheel as well). They are the thinner spoke profile type, load rated 1050k. The offset in which they are available is not crystal clear to me, with either ET10 or ET20 being stated in different places. I personally have a 18-inch set of black ones sourced through Bearmach which are ET10. ET10 being the reason I went for those, as I wanted to dump the spacers I had with the boost alloys previously, and keep a similar stance and turning circle on the 110. /Mat |
7th Jun 2021 12:19pm |
That's the first time I've seen load ratings quoted for these wheels. Can you share where the detail came from, please? Darren
7th Jun 2021 12:23pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Bearmach state the load rating on the website - 16" is rated at 975kg. Rgds. Chris |
7th Jun 2021 12:31pm |
Page 48 of Britpart's 17th edition catalog:
And for the Bearmach's 18-inch Sawtooth, rated at 1050kg, see https://bearmach1.helpdocs.com/wheels/what...r-ba-3460b which in this case is also confirmed on the back of the wheels I have received from them, see photo : Click image to enlarge /Mat |
7th Jun 2021 12:42pm |
muddypaws Member Since: 22 Jan 2013 Location: Leicestershire Posts: 122 |
Excuse my ignorance but does that mean if you jack one complete axle off the ground, the remaining 2 wheels supporting the full weight are at or just over their load capacity? Richard
Defender 90 SVX |
7th Jun 2021 12:56pm |
No, because the jack is still taking part of the weight.
Thanks for the load info, chaps. Does anybody have any figures for the OE wheels, by any chance? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
7th Jun 2021 1:51pm |
If you jack up one complete axle, then it is the jack itself that supports the weight of the said axle.
It does not change the weight being supported by the 2 wheels on the other axle. To determine the wheel load rating requirement, you need to apply a reasoning per axle, by taking the manufacturers maximum axle weight and divide it by two. Let's say the maximum weight on the rear axle of my 110 CSW is 1750kg as per JLR spec, then the load rating of each wheel should be 1750/2=875kg minimum. /Mat |
7th Jun 2021 1:56pm |
Forgive me - had a liquid lunch Richard
Defender 90 SVX |
8th Jun 2021 4:17pm |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
Just organising the garage and remembered this post . The OE LandRover sawtooths are rated for 1000kg, 16x7 ET20. And Made in Germany. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge omg how the flash shows the dirt Roaming around 🇳🇴🇨🇭 Last edited by Angus_Beef on 2nd Jul 2021 1:45pm. Edited 1 time in total |
2nd Jul 2021 1:36pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17565 |
Not forgetting of course that if you load the vehicle to max axle capacity and then cross-axle it, the two wheels carrying the weight will each as near as makes no odds be carrying the full axle load of their respective axle. It shouldn't be an issue on an occasional basis, however, since I have no doubt that there will be a safety factor of at least 2 in the wheel loading maxima figures. |
2nd Jul 2021 1:44pm |
