![]() | Home > Technical > Steering guard vs. protection bar |
It won't be 'as good' but does offer some protection and they are cheap and light. I guess it depends on what you use your Defender for as to whether the compromise is worthwhile. Having said that, lots of Defenders just seem to have steering guards fitted for show these days, so perhaps use isn't the only consideration anymore. Darren
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Ive got the NRC7009 bar fitted from new and Im not sure that it would do much more than collapse with a blow. its not the most substantial thing...
![]() Click image to enlarge ![]() Click image to enlarge Roaming around 🇳🇴🇨🇠|
lakelander Member Since: 07 Jan 2017 Location: Cumbria Posts: 100 ![]() ![]() ![]() |
I have the NRC7009 on mine but would like to fit Jate rings instead of the standard lashing eyes.
Will the Jate has be wide enough? Do they come in different widths? I think the Jate will have to go on the outside?So may have to put on longer bolts. Has anybody done this? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6166 ![]() ![]() ![]() |
I used to have that bar, thought it was the dog danglies, Camel trophy here I come....
until it hit a mild lump of ground and bent like a straw (into the steering damper ![]() Binned it, fitted a southdown and never looked back. I suppose you could slide in a piece of scaffhold tube inside the "bar" to beef it up a bit if you were that concerned. Last edited by diesel_jim on 6th Jun 2021 10:14am. Edited 1 time in total |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2326 ![]() ![]() ![]() |
Neither. Stop bolting shiny showy tat on your Land Rover and get some Gwyn Lewis steering bars that won't bend at the first sight of something more resilient than cheese
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
I think they come in suitable width to fit over the guard. See attached pictures. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 1995 Defender 110 CSW 1971 SIIA Lightweight |
Great - thanks for the shots. Could I ask a favour - please can you tell me the width of those fiitted.
Now just a decision of fitting those or going for a steering guard with built in recovery points.Steel or alloy ? Are alloy ones capable of sustaining a knock? Won't they just dent? Like the idea of a strengthening bar inside the hollow NRC7009. |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5117 ![]() ![]() ![]() |
Steering protection bars only offer minimum protection, plus they rust very quickly. Steering guards offer full protection and if you fit an aluminium guard will look good for years and years. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
I've never been convinced by aluminium steering guards. To be effective they need to be a lot thicker (typically 10mm v 6mm for steel) and as the brackets are still steel anyway, the weight saving is negligible. You can buy lighter ones - I've seen some with 6mm steel brackets and 6mm ali guards but they seem far too flimsy to me.
I do like guards with built in recovery points though - effectively two birds with one stone. Mines a steel galvanised one and is very sturdy: ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 2nd Mar 2023 9:45am. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17724 ![]() ![]() ![]() |
Safari Equip with receiver hitch:
I have fitted a Flatdog steering guard Quality 8mm machined aluminium. Countersunk fitting, hex head bolts. 8mm Mild Steel brackets zinc plated & Powder Coated. It appears to me to be a really sturdy piece of metal but I do agree that some others are flimsy. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
I have measured them. Seem to be 88mm on the insides. Difficult to tell exactly without removing them. 1995 Defender 110 CSW 1971 SIIA Lightweight |
I had them on my Camel Trophy Disco and on my G4 Challenge D3, but I don't see a point on a defender. They won't protect your track-rod and that is the one what bends mostly.
I have nothing fitted. ![]() Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 757 ![]() ![]() ![]() |
I have a modified protection bar with a beefed up bar. I ran over a boulder hidden under water along a river (the only way in and out plus was trying to outrun a flash flood with the group) caught some air time and inspected the bar, rather than being perpendicular to the ground, it now looks like a smirk. Have a dimple on the lower portion of the front diff cover too. Sheared three of the four bolts securing the steering box.
Steering box sorted, have the replacement front diff cover, have diff guards on order, replacing the bar with a plate type steering guard made of steel. Better be safe than sorry. But in fairness to the bar, my day would've been much worse had it not been there. While it's still on the truck, I'm thinking of unbolting it since it doesn't look so nice anymore plus can scrub the tires at full lock. |
