Home > Technical > TD5 90 Rear brake pads
mini Anaconda
Needing to replace the rear pads on a 2002 90 and have a couple of questions. The pads on there are fitted with pins and springs but pictures on the internet suggest the pad should be attached with pins and clips. Is it just a case of matching the relevant fitting kit with the relevant pad? Do the calipers themselves make a difference? (Both have been changed by previous owner)
What part number pad should I be fitting?
Many thanks. BORG - Bucks & Oxon 4x4 Response Group
Post #906495 4th Jun 2021 7:18pm
