Home > In Car Electronics > How do you extract an Alpine head unit?
Page 2 of 2 <12
Innuendomaster
John Baron wrote:
It's the connection at the head unit I am after, I'll see if I can find a head unit wiring diagram.
Cheers,
John.
The wire from the head unit will have labels, you're looking for "P Cont" wire. It's the switch wire to the Amp
Post #242228 9th Jun 2013 1:33pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Yes there was a label on the top of the radio with the wiring connections, it didn't match the diagram I downloaded but I figured the label actually on the set should be right and sure enough it was. The wire concerned was blue/white, which is a colour I have heard mentioned on other threads but didn't want to use without confirmation.
Alls well now and the LR is 'Woofing'.
Thanks to all contributors.
John. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #242305 9th Jun 2013 6:46pm
nitram17
|Is it possible to get the alpine unit out without the proper keys/tool if so where are the locking tabs in relation to the unit?
Post #905644 29th May 2021 6:54pm
Sulisuli
Small screwdriver each side to spring the lugs located at the top each side Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #905652 29th May 2021 7:58pm
nitram17
Thanks Suli Thumbs Up
Post #905664 29th May 2021 8:43pm
Page 2 of 2 <12
