![]() | Home > Orders 2022MY (L663) > 11.4inch display |
Al_Ra Member Since: 03 Mar 2021 Location: Oxfordshire Posts: 65 ![]() ![]() |
Same boat - my SE is due to built next month and is specced with the bigger screen.
I think we'll probably get them (someone on FB posted an image of their newly delivered S/SE with larger screen) but if not I'm not overly concerned since I think the smaller one fits the dash design better anyway. |
Kubrick1978 Member Since: 01 May 2021 Location: Midlands Posts: 101 ![]() ![]() |
Agreed! Not the end of the world if we end up with the smaller screen, but interesting how JLR start limiting minor (and relatively cheap - £140) upgrades to the HSE models. They're obviously very aware that if you pick an S or SE and go for a few extras you end up with a vehicle that looks and feels the same as an HSE (aside from the Windsor Leather) - and can have more off road ability for less £££ (particularly with larger tyre walls). I suspect they may just be pushing the XS. The way I've specified my Landy, the only thing that is 'low-end' is the cheapest D200 engine - but it looks like the 6-cylinder D200 works favourably and is comparable to the 4-cylinder D240 - which gets a great write-up. The lack of extra torque and HP doesn't really bother me. I guess they need to differentiate more between S/SE/HSE specs - but if I was ordering a new £70K P400e SE I'd expect to have a larger screen if I wanted it.
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 237 ![]() ![]() |
Damn it! I wanted the bigger screen too, but like you, I think the smaller screen works well with the the layout of the dash. Maybe something to do with the shortage of components, making sure they have enough to fulfil the orders for the higher spec. I'm hoping to confirm my order today of my 110
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
It’s not unknown for there to be spec glitches with the updates to the configurator so check with your dealer before getting despondent that you might not be able to have the bigger screen Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1440 ![]() ![]() ![]() |
I noticed on the xs that it has cruise control as standard but you can't spec adaptive cruise control which seems a bit weird as it's probably just a part of the software to switch it on
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
The_hog Member Since: 02 Aug 2020 Location: Reykjavik Posts: 36 ![]() ![]() |
One thing the bigger screen has. It´s nearer to your fingers about one inch, am I not right. So, less stretching.
4B4B Member Since: 30 Apr 2021 Location: Midlands Posts: 83 ![]() ![]() |
I was on the fence about if I should spend the extra £140 to get the larger screen. The cost was no issue really, and under normal circumstances it would be a no-brainer. But there was something I liked about the smaller screen fitting in with the crossmembers. Watching one of the JLR Defender Design Team’s videos confirmed to me, where they talked about keeping the instruments in the lines of the dash, the reason I liked the smaller screen.
Well, it’s dead easy now, the choice has been taken away on the model I’ve ordered! Defender 90 HSE 250D 2022MY - Gave up after two failed orders |
