![]() | Home > Td5 > Suspension setup difference between TD5 CSW / Hardtop / Pick |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3483 ![]() ![]() ![]() |
Csw have dual rate springs. Soft when empty and get harder when loaded.
Gross weight is also different from the HT or pickup. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
90GTR Member Since: 05 May 2020 Location: London Posts: 201 ![]() ![]() ![]() |
Thanks Dinnu!
Yes this hardtop is very crashy on uneven road |
Jamie1992 Member Since: 26 Jan 2019 Location: Haxey Posts: 18 ![]() ![]() ![]() |
Is it possible to put duel rates shocks on a pickup/ht?
Yes, it is possible.
Have a look at the table with part numbers on this site: http://www.red90.ca/rovers/springinfo.html Unfortunately this list does not have the latest spring specs fitted on puma. Spring rate will affect how harsh your ride is. The higher the spring rate, the faster the spring will push the chassis up after hitting a bump. I suggest you first try to determine what springs you have then you know your current spring rate. Then choose a spring with lower spring rate. When going for lower spring rate, you will also need to choose longer spring, as the spring will compress more for the same weight. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
