![]() | Home > Off Topic > Discovery 2 Max tyre size |
You've got no chance with that size, even with a 2 inch lift. They're more than 4 inches bigger than standard and will foul the rear edge of the rear wheel arches and probably also the trailing edges of the front bumper.
Without a lift, you should be able to go up to 245/75, although it might still be touch and go on the rear arches - depends on the tyres. You'll need a lift to go up to 235/85 and will still likely need some minor surgery on the rear arches. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I think you should go the whole hog an have an Icelandic look
![]() ![]() http://www.flickr.com/photos/kiddiuk/2507866505/ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17588 ![]() ![]() ![]() |
I used to run 245/75 x 16 BFG Muds on my 2002 (pre-facelift) with no rubbing issues at all with no lift. When I changed to 265/75 x 16 Muds I had to trim the bottom of the front wheelarch liners by about one inch. Note however that I have a Gulf-spec front bumper and the UK/ROW bumper may be more of a problem. Apart from this the 265s don't rub even on full suspension travel. I am on stock alloy rims but they are the wider option - the standard narrower ones may rub.
You will not get anything larger than this without a lift. With 265s the speedo will under-read by about 10%, it is spot on with 245s. |
