Home > Technical > Help request
slon4eto
Russia
Help request
Hello, I want to change my clutch kit.
My truck is a Land Rover Defender 110 HARD TOP 300TDI. It was produced on 1997. The engine is 300tdi. The gearbox is R 380 .
Please answer the following questions:
A) Which clutch is preferable / you would use /, for what reasons :
1) Land Rover Performance Clutch Kit - OE STC8358
manufactured by the company SACHS : https://www.sachsperformance.com/en/clutch...00950701-s
OR
2)POWERspec TDI 200/300tdi
manufactured by the company LOF clutches : https://lofclutches.com/shop/clutches/clut...ty-clutch/
B) For LOF clutches:
1) What is the % higher transmitted torque of the POWERspec TDI 200/300 tdi kit compared to OEM? https://lofclutches.com/shop/clutches/clut...ty-clutch/
2) What is the torque capacity of the POWERspec TDI 200/300 tdi kit in Nm ? https://lofclutches.com/shop/clutches/clut...ty-clutch/
3) What is the clamping force /eject fors/ of the POWERspec TDI 200/300 tdi kit in N or kg ?
4) What will be the weight of the pedal if I install /put/ a 2.8 TGV HS International POWERspec kit - (Also fits TDI) and a DEFENDER POWER MASTER BUNDLE Spring and Master Cylinder on my truck?
https://lofclutches.com/shop/clutches/clut...rspec-kit/
https://lofclutches.com/shop/clutches/peda...-cylinder/
5) The weight of the pedal from point 4) is equal to or less or greater than if I mount /put/ on my truck POWERspec TDI 200/300 tdi kit and Defender POWER MASTER BUNDLE Spring and Master Cylinder?
Thank you in advance.
I do not speak English! I use google translator.
Post #905045 26th May 2021 6:14am
slon4eto
Russia
I close the failed discussion.
Post #910470 2nd Jul 2021 2:16pm
Co1
If you don’t yet have the answer I would suggest you contact Luke at LOF directly.
Post #910519 2nd Jul 2021 8:14pm
Dinnu
Was answered in another thread. https://www.defender2.net/forum/topic78705.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #910626 3rd Jul 2021 4:31pm
slon4eto
Russia
Thank you
Post #910660 3rd Jul 2021 8:20pm
