Home > For Sale & Wanted > [Wanted] Td5 loom connectors |
130dreamer Member Since: 29 Feb 2008 Location: Romford Posts: 100 |
I have got a TD5 main loom with the connectors.
Click image to enlarge Click image to enlarge Looking for about £100 for it. |
23rd May 2021 7:47pm |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
Thanks, I'm just looking for the connectors (unless you want to cut them off?!? )
24th May 2021 9:45am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2947 |
Try Paul Mc. On here
24th May 2021 10:06am |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 |
You need some Sumitomo HW series, grey can be found below. The female orange will be more difficult to track down, from memory they are keyed the same as the grey anyway so you could use grey in place of orange.
Bulkhead plug - https://www.automotiveconnectors.com/14-wa...emale.html Wing plug - https://www.automotiveconnectors.com/14-wa...-male.html Terminals - https://www.automotiveconnectors.com/AC69-15000106-T.html Wire seals - https://www.automotiveconnectors.com/wire-...125mm.html Cavity plugs - https://www.automotiveconnectors.com/dummy...black.html 1989 90 4.3 V8 2012 L405 OF 2014 D4 HSE Lux (SOLD) 2015 90 HT (SOLD) @d9o.mf |
24th May 2021 10:08am |
C0377
C0391 ------------------------- 6 pin-----Grey C0378 CO392---------------------------4 pin-----Grey CO376----------------------------9 pin------Orange C0390 chassis and engine looms |
24th May 2021 11:22am |
C1266-------------------------10 pin-------------RH
C1267 C1265-------------------------14pin--------------LH C1264 bulkhead loom to the wings, https://www.defender2.net/forum/post904741.html#904741 |
24th May 2021 11:39am |
Thanks for the links!
26th May 2021 9:47am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
I think i should have all of these connectors on a donor loom except for the orange bulkhead one which is damaged.
Will check whilst I am at the workshop tomorrow. What sort of price would you be willing to pay for the set? Just want to balance whether it is worth writing off the donor loom. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
26th May 2021 3:38pm |
I guess i'd be paying about £30 to get the connecters I need new
26th May 2021 10:27pm |
