Home > Puma (Tdci) > Drive belt - life expectancy |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
does it show signs of wear ? 2.4 90 XS
21st Sep 2011 3:21pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17551 |
Not that I can see.
21st Sep 2011 3:25pm |
keep an eye out for the wire in the belt starting to show then change it 2.4 90 XS
21st Sep 2011 3:28pm |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
On my check sheet it says 200k km which is about 120k miles so if it looks ok it probably is. 130 crew cab
98 V8 Disco |
21st Sep 2011 3:57pm |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 328 |
Yes, UK service sheet shows replace drive belt at 120K miles
21st Sep 2011 6:26pm |
Thank you!
23rd Sep 2011 12:56pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
If in doubt change it as it only takes 30 minutes but draw a diagram of all the toothed gears first as it will help with re-fitting the correct way. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
23rd Sep 2011 1:23pm |
