Home > Technical > Any ideas why? Traction control light and ABS saying on |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 323 |
Probably ABS fault, there will be fault codes stored which you need to get read before we can help further.
21st Sep 2011 6:05pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Check that none of the ABS harness on each wheel hasn't fouled the suspension. The most common problem for both lights being illuminated is a crushed harness. Other issues which can cause it are a faulty wheel speed sensor or an incorrect air gap in one of the sensors though this can cause the TC to operate at any time. If you have a fault code reader or even better a way of checking the live data in the Wabco module you will be able to tell which sensor is causing the problems. The voltage at the wheel sensor should be between 2.1-2.3 volts. The DTC will give the reason but not the cause.
HTH Brian. |
21st Sep 2011 6:27pm |
Landy...
'Heads up!' Similar problem I had: http://www.defender2.net/forum/topic2394.html?highlight=abs http://www.defender2.net/forum/topic7119.h...termittent Hope this helps! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Sep 2011 7:37am |
Any resolution to the problem yet?
5th Oct 2011 7:31pm |
