Home > Modifications & Maintenance (L663) > Rear Loadspace LED lightning by Defender3D |
cyberhusky Member Since: 09 Feb 2021 Location: Luxembourg Posts: 275 |
Defender3D has some interesting 3D printed parts for your New Defedner 2020
I soon as I get my Def I will order on of these boot LED lamps https://defender3d.co.uk/products/ols/prod...d-lighting What I really like about this solution: no drilling, no taking apart of your Defender, just some clipping and it works with your other boot lamps. Edit: changed the link 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history) Last edited by cyberhusky on 21st May 2021 12:59pm. Edited 2 times in total |
21st Apr 2021 9:15pm |
SN Member Since: 29 Jun 2007 Location: SK6 Posts: 729 |
I like this a lot - noticed the default lighting for the first time the other day and I can see if you have anything stacked on the loadspace floor its going to get obscured - on my prospective mod list one of these goes! Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
21st Apr 2021 10:07pm |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
I fitted one and the upgraded Powerful UK lights
This is a good addition. For my OCD - there was a small gap between the light and roof - that sunlight came through when you were driving and looking in the rear view. I fitted some 25mm x 5mm thick foam to the back (between the two end caps) sorted the issue (or non issue depending on your view point) I let Tim (owner of 3D Print) know and he was going to investigate fitting similar to them. The light has a bend in it - but the roof is a curve so the 2 bends did not quite match This foam fills the gap. Click image to enlarge |
22nd Apr 2021 4:13am |
Ordered mine today - along with a protective bumper top fitting too. Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history) |
21st May 2021 12:17pm |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1103 |
Got a link ? The one at the top of the thread is not working. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
21st May 2021 12:28pm |
Add one to the basket and then go create an account - dead easy - and your basket will still be hold the item for purchase when you get properly logged in via a link from your email I'll undoubtedly buy more from here going forwards... Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history) |
21st May 2021 12:30pm |
DWM73 Member Since: 23 May 2021 Location: North Lanarkshire Posts: 38 |
Fitted one myself. No tooling required at all.
12th Jun 2021 9:16pm |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 422 |
Broke it, during my holiday in Wales 🏴
Click image to enlarge Not happy. No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
22nd May 2022 6:27pm |
Hello
When I ordered my led lamp from Defender3D I got a pair of replacement clips. 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history) |
22nd May 2022 6:49pm |
