Home > Td5 > Td5 Head Gasket |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I would pull the head and see from there. You never know what you buy if you go secondhand.
For the ECU I believe you can change to the newer ecu on the older engine. However a discovery ecu might not work. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
10th Apr 2021 6:30pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 818 |
Thanks for reply Roel thinking along the same lines myself now, as finding a good 15P engine here will be a struggle and not cost effective to bring from the UK anymore as a result of Brexit
11th Apr 2021 6:42am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5708 |
Talk to Turner engineering.
https://www.turnerengineering.co.uk/ |
11th Apr 2021 9:06am |
Burgerboy78 Member Since: 04 Apr 2019 Location: Essex Posts: 8 |
Hi,
I had the head gasket go on my W reg TD5 at 99k miles. As mentioned above, I bought the head gasket and head rebuilt kid from Turner engineering. Also put the metal head dowels In which were also from turner. I had the head skimmed, although only a tiny bit. Some people say you shouldn't have it done but ive had no problems since. Whilst there I replaced the Injector loom also. I done this all myself as I am quite mechanically minded and it was fairly straight forward. Plenty of guides online if you are going to tackle it. |
15th May 2021 8:18pm |
