Home > Faults & Fixes (L663) > OK to drive with caution 2 wheel drive only Traction reduced
nigelsim18
Anyone had this error on the new Defender? I was right over at ~22 degrees with rear wheel in the air when it appeared. It didn't reduce me to 2 wheel drive as it suggested and after getting to flat ground a start of the vehicle cleared it and it's not appeared since.
Error on instrument screen: OK to drive with caution 2 wheel drive only Traction reduced
Searching suggests the error has been seen on Evoque and Discovery, and rear diff seems to be blamed. My vehicle does have the rear e-locker for what it's worth. Did wonder if due to the angle fluid had caused a sensor to believe it was low?
Thoughts?
Post #902772 12th May 2021 8:41pm
J77
Have a look here
https://www.defender2.net/forum/topic76950.html 24MY 90 D250 HSE, Tasman Blue
Post #902796 13th May 2021 4:10am
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
A software update fixed mine
Post #902827 13th May 2021 10:07am
nigelsim18
Was that a software OTA fix or dealer fix?
Post #902896 13th May 2021 5:57pm
