Home > Maintenance & Modifications > Brake caliper piston kit STC1278 - Piston diameter?
Dinnu
I think my early 90, the pistons on the front caliper are due for replacement. Measured the piston, and confirm it is the 41mm diameter. Can anyone confirm if the kit, STC1278 is the 41mm piston size, and not the 46mm?
I believe the individual pistons that I need is 606683, but the kit would be cheaper.
Thanks. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #902562 11th May 2021 2:07pm
hank
Put stainless pistons in mine recently and made this very mistake! STC1278 are 41mm > 110 XS Double Cab
Post #902566 11th May 2021 3:02pm
Dinnu
Thank you Hank. Sorry about your mistake. I need the 41mm. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #902569 11th May 2021 3:49pm
