Home > Off Topic > weight limit on a recovery truck
Page 2 of 8 <12345678>
familymad
Bluericky wrote:
My 130 was delivered 250 miles on what looked like a totally inadequate transporter, given the size of what it was carrying !
The winds that day were approaching 55 mph . Thank goodness it made it .
Geesh Shocked 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #902297 10th May 2021 7:21am
Smyles_
Denmark
Terrible photo from a terrible day but, this is what collected me when some calliper bolts fell out... Whistle
My guess is that it was ok? Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #902325 10th May 2021 9:46am
rallysteve
VOSA could have a field-day around here! There are hundreds of 3.5t transit flatbeds, including a load of badly home made ones carrying large vehicles (incl. other transits, Jags etc.). They could just hang around outside the local banger racing track and have their fill of defects and overloaded vehicles.
Then again there are also plenty of 7.5t 'privately owned' trucks around here which do plenty of cash in hand scrap car buying and have no tachos and I am sure in many cases no C/C1 licencing. One of the usual suspects also uses our residential street as a casual lorry park for 7.5t and larger vehicles. 02' 110 TD5 Double Cab Rebuild Thread
Post #902327 10th May 2021 9:54am
excossack
Do these conversion not need to be inspected to ensure they are safe, have the correct plating showing max weight etc and be registered as a recovery vehicle and not still be registered as a box van ?
Or can anyone get an old transit and weld up a new bed and call it good? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #902343 10th May 2021 11:07am
kenzle8a
miker wrote:
The issue (as I understand it) with 7.5t is it's only really a relevant class in the UK, so most 7.5t trucks are downplated 12t chassis!
Have to be really careful in my industry (broadcast and events) as it's very easy to wheel 4t of kit into a 7.5t truck with a box body on it... The last one I had to deal with, could only put 2200kg on it!
Its the same with 7.5 tonne horse boxes, save for the hunt lorry style ones most of them are probably running overweight without even knowing. Its why we have the Landy on the farm as towing with it is easier to work out GTW & MAM.
Most of the 7.5 tonne boxes we looked at could only take 2.2 tonnes of load, which when you add three horses, tack, kit, water, hay etc too you are easily over the limit, ours aren't even that big as they are all sub 500kg ponies.
Post #902365 10th May 2021 12:41pm
en48
United Kingdom 2009 Defender 90 Puma 2.4 CSW Bonatti Grey
Hmmm...
I've got this to look forward to on Friday. I've hired a 3.5t beavertail to go and collect a car.
In their defence, they did 'make me aware' that the 3.5t was the total limit, and that the van itself was a little over 2t.
I'm retrieving an old MGB. Mostly intact, but no roof (note to self - take tarpaulin), windscreen surround or any glass...
My (perhaps foolish) assumption was that I'm legal.
Might go away and check now though..!
Post #902407 10th May 2021 3:42pm
excossack
Maybe this helps?
https://classics.honestjohn.co.uk/reviews/mg/mgb/specs/ 1999 Defender TD5 110
Regards
John M0VAZ
Post #902409 10th May 2021 3:48pm
Bluest
Its slightly more involved than just adding the two vehicle masses together and then subtracting from the gross limit. Axle weights need to be considered as its entirely possible to within the gross but over on an axle. 2007 110 TDCi Station Wagon XS
Post #902410 10th May 2021 3:48pm
rallysteve
Doubt an MGB (even one still mostly made of steel Laughing ) much over a tonne so I wouldn't be too worried about that sort of vehicle, that is exactly what 3.5t trucks are ideal for!
Post #902412 10th May 2021 3:50pm
Projectblue
Yeah, 6500kg GVW Iveco with an ali slide. Plus it's a pro recovery company so they won't take a chance. New project and it's green: www.projectoverland.info
Post #902452 10th May 2021 8:05pm
Projectblue
Re: weight limit on a recovery truck
Stacey007 wrote:
Hello
The Van is classed as a 3.5T so does that mean say the van weights 2T you can only carry 1.5T
I thought it was interesting as doesn't look obviously wrong?
The thing to remember is physics. The weight aft of the axle increases with the distance away from the balance point.
Also, an easy (but not full proof way to work out a van size is by it's numbering. Most german vans use weight.power so a 316 is 3000kg, 160PS and a 516 is 5000kg etc. New project and it's green: www.projectoverland.info
Post #902454 10th May 2021 8:12pm
It says something about the engineering of these 3.5t vehicles that it actually moves when overloaded by 2t:
Post #902846 13th May 2021 12:24pm
Rashers
I was watching Bangers and Cash on Yesterday the other day. What do Mathewsons use for shifting all those classic cars around? I think one of their vehicles is a Peugeot. This would be a 3.5t van, wouldn’t it?
They also tow a car transporter trailer some times.
Are their vehicles ok?
Post #902849 13th May 2021 12:46pm
Bluest
You are probably ok with many classics on a 3.5t transporter. Just depends what you are carrying. Modern cars have just got really heavy and it’ll get worse with electric ones. The key is making sure you know the payload of your van and the actual weight of what is being carried. The trouble is you’ll be running so close the limit a lot of the time that ensuring you are never over on at least an axle if not gross, will be hard.
Towing with a car trailer is still potentially problematic as you’ll probably need a tachograph and o-license if the max weight of the combination is over 3.5t. So, whilst you might be running comfortably within the legal weights for your vehicle, you are not meeting the regs for operating a commercial vehicle. The Traffic Commisioners do not have much of a sense of humour about this stuff and your vehicle can be scrapped. This catches a lot of people out who tow commercially using an SUV, or they hope they’ll be able to convince the authorities they are towing for leisure if they get pulled.
Really a lot of these businesses ought to just bite the bullet, get a bigger truck and an o-license. 2007 110 TDCi Station Wagon XS
Post #902852 13th May 2021 1:17pm
cee-b
en48 wrote:
Hmmm...
I once recovered a friend's MGC roadster on a very heavy trailer connected to my Vauxhall Viva estate (I was the only 1 of our little crowd with a towbar).
The first indication that something might be wrong was the back end of my car lifting a few feet in the air as the MG was driven onto the back of the trailer.
The next was total brake fade as I approached a set of traffic lights on a downhill; we went through just as they turned red, with lights flashing and horn blaring. I eventually brought it to a halt when the road levelled out.
I definitely learned about towing from that!
In my defence, I was a teenager driving my first car. I'm now a pensioner and have never knowingly towed overweight since.
Good luck with the (presumed) restoration of the 'B'.
Post #902854 13th May 2021 1:33pm
