Home > Modifications & Maintenance (L663) > Wheel arch protection |
dazadd Member Since: 28 Feb 2021 Location: Cranwell Posts: 12 |
Fitted the Wheel arch protection (VPLEP0379), greatly improves the look of the car in my opinion and makes it look more like the off road machine it is, rather than an urban run around, although the best 4x4 no matter what the use!. Before and after below.
Fitting was straight forward but the old wheel arch trims are unusable once removed, no matter how careful you are, the white clips seem to deform and snap the clip attachment points, be warned if you need to remove them for any reason. Click image to enlarge Click image to enlarge D240 110 First Edition (1XD3, 4xD4s and a D5 now gone) Member of Disco Forums since 2006 |
9th May 2021 7:41pm |
SN Member Since: 29 Jun 2007 Location: SK6 Posts: 729 |
Yep - I'm a big fan pf the extended arches too!
Click image to enlarge Though I accept if you have an X-Dynamic its not so straightforwards - standard wheel arch extensions won't match up with the gloss black trim at bottom of the doors. Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history) |
9th May 2021 10:53pm |
Brookester824 Member Since: 26 Mar 2021 Location: East Yorkshire Posts: 18 |
Click image to enlarge Love em |
17th May 2021 2:29pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 |
I’m still debating if I should get them or not.
I’ve fitted the metal pedals and the load space tread plate. The metal pedals were only £32 or something for the genuine ones compared to LRs £100+ 24MY 90 D250 HSE, Tasman Blue |
17th May 2021 3:06pm |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 |
Not to disencourage you. Had mine fitted by the dealer with delivery of the car. After having had some unplanned physical contact with hostile environment, one wheel arch has had to be replaced together with some minor cold metal forming and paintworks. Has been done by professional repair shop (well known, proven reliable, and with good reputation) with OEM spare parts. Well, replaced wheel arch started to come off after just one week with two gaps of about 1/4'' wide at the front and rear most bent postion of the arch. Sticky tape not sticky enough. |
18th May 2021 10:55am |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
I had the same - both sides - in same spot - I guess the dealer did not prime well when fitting.
They just changed them - not seen the car since ... should be returned tomorrow? |
18th May 2021 1:36pm |
