Home > Technical > Newbie questions - new to me 2007 Defender |
Niels906 Member Since: 04 Jul 2020 Location: Bussum Posts: 44 |
Goodmorning all.
So, we finally took the plunge and bought a 2007 Puma Defender. 290000 km on the clock. What would be your main concern when looking at these photos? Anything you would be worried about? Drives great, starts easily. No crazy noices that I can hear as a newbie… Photos are attached to the message. |
8th May 2021 8:18am |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 827 |
No photos on message? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
8th May 2021 10:08am |
Absolutely. The photos are in the gallery.
8th May 2021 10:15am |
Thanks! Good to hear!
8th May 2021 2:25pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3469 |
Nice Defender.
As a start check or better replace all oils, gearbox, tcase, axels, swivels and steering. Then a good steam wash to get all the oily stuff clean.. take it for a short spin and re check for fresh oil leaks. This way is easier to pinpoint any source of leaks. Then and probably more important corrosion. I am not very knowledgeable on 110s, but some areas need closer inspection, like seatbelt mounts, and C pillar. They all suffer from galvanic corrosion. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th May 2021 2:58pm |
Thanks. The items you mentioned are indeed on my to do list. As is an anti corrosion treatment. Thanks for your input.
Niels |
8th May 2021 5:41pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1804 |
As Dinnu says, plus I would change all the suspension bushes before doing the anti rust wax - less messy that way.
Timing chain as well? Good luck. Keith |
8th May 2021 6:43pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
for the mileage and age id say it looks good DEFENDER 90 TDCI XS,
8th May 2021 7:00pm |
Thank you everyone for all your help and ideas. Will start adding your suggestions to the to do list.
11th May 2021 7:31pm |
