Home > Tdi > Transfer box diff fault
Tomo44
United Kingdom 1996 Defender 90 2.5 TD CSW Epsom Green
Had vibration from drive train, took the front drive shaft off to check front end, found I had no drive to the back wheels even with diff lock on, hand break still works, could it be diff fault or transfer box?
Post #901948 7th May 2021 10:51pm
Dinnu
Probably just the center diff lock did not engage (at fault or ceased linkage). Did the dash light for center diff lock illuminate?
The handbrake locks the rear propshaft, so as long the rear diff is ok, it will work. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #901954 8th May 2021 5:41am
landy andy
How are you testing this?
If you have no drive to the rear, and diff lock not engaged you wouldn’t be able to drive it.
Post #901958 8th May 2021 7:16am
Tomo44
I will make sure the diff lock engaged then remove the front prop shaft and see what happens, it's a plan.......can't get the light on to confirm diff lock engaged could this be causing my vibration at speed, are faults with diff locks common the link looks good and it will go into low ratio
Post #901974 8th May 2021 9:32am
Ianh
If you have been manoeuvring to park it can then be difficult to engage diff lock, also if the gearbox is cold or the linkage needs lubricating. So could be any of these or a combination of them. Hence every time I drive, just before I park at home , I run the box through a diff lock sequence a few times and do the same between high and low range. Just to keep everything free and working. A short drive forward and back in a straight line generally fixes the issue if it won’t engage.
Post #901988 8th May 2021 12:23pm
