![]() | Home > Maintenance & Modifications > Turner Engineering Cylinder Head Question |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1885 ![]() ![]() |
I have, about a year ago now. Unfortunately I did so many other things at the same time that it would be impossible for me to comment on the impact of any single thing.
In a way it might have been good to do them all one at a time, but that just wasn't feasible. The relevant things that were done were; Turner gas-flowed head; Fuel pump professionally refurbed/tweaked; VNT fitted; Full width Allard intercooler fitted; Griffin exhaust. Oh, and a taller 5th gear in a refurbed gearbox As you can appreciate, all of these things would have an impact on 'performance' (sic - it's still a 300Tdi) and fuel consumption. The last thing to go on was the Turbo, on the basis of BAS advice to let the rebuilt engine run for 500 miles before doing a couple of oil changes and then fit it. So before the turbo went on, the car performed much better. I suspect the biggest single change/impact was the fuel pump. I was told that mine was ca. 15% below standard when it was checked over prior to the tweaks/refurb. Now, the car will sit very comfortably at 60, get easily up to 70 and beyond if I can be bothered. The biggest change has been the low down grunt, making joining and keeping up with traffic a lot easier. So, on the open road I drive much as I used to; around town maybe accelerate a bit more up to your 30/40/50 or whatever. Having said all of that... in it's original state, I reckon I was getting ca. 29/30mpg. Now I'm getting ca 29/30mpg! I know it would be better on a long dual carriageway/motorway run - but there's not been much opportunity for that lately. The car pulls better and is 'smoother'. Sorry - not precisely what you were after. ![]() 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 363 ![]() ![]() ![]() |
thanks for that. i now find as well as head, i have to have a new timing case inner. whoever did a cam belt change a few years back didn't tighten bolts properly and there's lots of damage and wear and even an insert like a rivnut with a new thread in the timing case! 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
At the garage, when I was getting my engine swapped in or out, they were doing a snapped timing belt on another 300Tdi.
There was a lot of 'fluff' from the snapped belt, and some chewing of the pulleys. Digging about I found a loose and damaged bolt in the bottom of the case. It looked like the bolt had come loose, fallen in between the belt and the pulley - damaged the pulley and snapped the belt. Would the 'rivnut' actually be a proper helicoil? I had one of the spark plug threads professionally redone on one of my RR cylinder heads, and they've used a helicoil, or something very similar. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17724 ![]() ![]() ![]() |
Helicoil or more likely Timesert, I would think.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2733 ![]() ![]() |
Very common to find helicoils or similar in Tdi timing cases - they’re prone to bolts seizing and snapping. There are two in mine. Done properly it’s perfectly acceptable.
this one sadly won't allow proper torquing. so new timing case inner cover. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
I think it is, but it won't allow torquing up to the right number. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
