![]() | Home > Puma (Tdci) > Power steering noise? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
I have a 2.4 and due to the same symptoms I had the power steering fluid changed. The noise continued on and off and as it only occurs rarely it is hard to say if it is cured or not.
For the 2.2 the amount you need is listed as 1.6 litres, which is different to the 2.4. This is from the Advanced Factors service items page. You cannot overfill as you only fill to the mark on the dipstick attached to the cap. I'd get a garage to change it as it might be a bit awkward on your own. Then again someone could come on and give directions for doing a solo change. Anyway good luck. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
