Home > Technical > Help needed, Defender wing repair section
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Is this section available? Searched net but can't find it, not sure of the part name or description needed to find it.. Just stripped the wings of a 300 tdi and it's corroded to nothing where it bolts the the chassis. Thanks Craig
Post #901097 2nd May 2021 7:01pm
Zimblewinder
Australia 2000 Defender 130 2.5 TD HCPU Chawton White
If you can't find one this would have to be the easiest piece to fab up. Its mostly flat and you still have the original for the position of the holes. Use sockets and a vice or press to press in the inset places and a shot bag and hammer to get the indented bottom area. (practice on a scrap piece of ally first - its soft so go slow). I think you'll find the end product up to scratch and you'll be really satisfied with your effort. Show us how you go if you try to DIY.
Post #901309 4th May 2021 12:15pm
From the diagram on LR Workshop, it doesn't look like that part is available separately, unfortunately.
https://www.lrworkshop.com/diagrams/land-r...mbly_52677 Darren
Post #901319 4th May 2021 12:41pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
N/S required?
Damn, skipped one of these about 8 months ago! Rest of the wing was FUBAR'd afterb a minor RTC, but that bit was definitely good.
There are(was) lots of replacement wing sections including that part available for not much money when I was looking.
Post #902082 8th May 2021 10:01pm
Moneypit
Thanks guys for all your suggestions & advice, going to look for damaged wings and drill the sections off to repair what are a good pr of wings other than the corroded front mountings. Craig
Post #902735 12th May 2021 6:52pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Did you try YRM? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #902738 12th May 2021 7:01pm
