Home > Maintenance & Modifications > Bumper fixing plate - which one |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 399 |
I’ve used both, the spring ones are a bit easier to fit as they clip onto the bumper, the T shaped ones just slot in between the jacking point and the bumper.
My bumper is currently mounted using nuts and bolts all round. I wouldn’t say any method is better or worse than the other really. |
2nd May 2021 7:28am |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
Thanks Jimbo, I appreciate your time. I think I will make myself the T version as I just need to put back the bumper until I can fabricate some dumb irons. I then want to fabricate my own bumper - but other essential maintenance and projects first!!!
2nd May 2021 8:10am |
No problem, it’s what the forum is here for
Would be easy enough to make a space, they are only a drilled and tapped plate after all Be good to see what bumper you come up with 👍 |
2nd May 2021 8:34am |
I have an idea of what I want to produce. I am a bit of a tinkerer/fabricator. I an not supper bling nor off-road, I am more practical minded
This is all currently a pipe dream, but I am considering a front bumper and rear bumperette combination. I need to consider the strength of the chassis and rear cross member as want to look at supporting the vehicle from it. It would include its own "axle stands" but supporting from the bumpers. I don't like using stands on the chassis! My thoughts are lifting the chassis safely for doing my own maintenance. I expect to do a chassis swap sometime in the future, so I want everything I do to be transferrable. I also want a swing away carrier incorporated in the rear. But I need to sort the dumb irons and finish my rocksliders first!! |
2nd May 2021 8:57am |
