Metal on metal grinding sound at 1600-1700 rpm
I have a ridiculously annoying metal on metal sound at 1600-1700 rpm. Took it to EH Douglas and they ‘adjusted’ the turbo heat shield, made no difference so I checked it and pretty much all the rivets were sheared so I’ve removed it to help diagnose. Shearing sound is still there so I checked what I think is the CPS heat shield as a few posts mentioned it. I’ve added a picture of what I think is the CPS heat shield but it looks different to others.
I’ve had the Defender for 2 months now so it’s still under warranty but I’m just trying to fix it myself to save the 2 hour drive back to the dealer.
While I was under there I also spotted oil coming from the transmission, not dripping but definitely collecting, should I be worried or is this usual Defender behaviour.
1st May 2021 7:30pm
williamthedog
I would be investigating the oil leak, I don't think it's been leaking that long but check it out.
1st May 2021 8:55pm
Ashcurze
Thanks I’ll get it back to the garage I think. I wish I could locate the noise though in the meantime.
Perhaps the brake drum is on too tight. Maybe adjust it or the brake cable? I know mine occasionally tensions itself and makes a noise similar to what you described. I give the handbrake lever a good waggle and it does release it. Monsieur Le Grenadier
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
